DIY: Remove and replace valve cover gaskets and spark plugs
Rating: Thread Rating: 2 votes, 4.50 average.
Old 01-24-2011, 01:39 PM
kostas86's Avatar
V8, Flat 6, V6, & Turbo flat 4
Awesome write up.
Old 01-26-2011, 10:37 PM
henry47's Avatar
asdf
i followed this writeup a few weeks ago and it was fairly simple. took about 3 hours. if you're hesitant, don't be. it's straight forward. only thing i forgot to do was wipe the dripping oil when i put the valve cover back on.
Old 01-27-2011, 12:31 PM
SZMB's Avatar
2004 E500 CLK320
Originally Posted by Zaphodsplanet
Great DIY instructions... thanks for posting them. But I have a couple of questions.
1) Now that it's been close to 6 months since you made the fix.... are you leak free? Or have any leaks developed?
2) It doesn't look like any kind of sealant was used at the factory. My 04 e320 is sorely in need of me doing this fix.... but it also has 102K miles. Probably could have actually done this at 85K.... but it was just seeping at that point. Anyway... if you have to go in and do this again you're going to have a really fun cleanup job with the sealant you added. Did you ever find any instructions on how this is spec.'d on something like a WIS? Or has anyone found torque specs for the valve covers?
I'd just rather not cover everything in sealant if I don't have to. It never worked well long term on cars I've had in the past.
Thanks for posting the instructions.
I've driven the car 12k mi after the gasket replacement, and no leaks so far. If there's a leak, you'll notice it after 20 mins of driving. The factory does not use sealant because the engine is assembled off the car (so there's plenty of room to work with) and since all parts are new, they fit perfectly. The dealers also use sealant on replacing these gaskets. If you don't use sealant, it would be very difficult to align the new gasket with the rims of the valve cover and the engine block and chances are that it'll leak (w/o sealant).
tich65a (03-26-2017)
Old 02-04-2011, 03:38 AM
mike2291's Avatar
e320
so im planning on doing this probably next week when my parts come and i was thinking is it easier to access the plug by removing the valve covers?
Old 03-24-2011, 06:43 PM
LexDiamonds's Avatar
2004 CLK500
Does anyone have the part number for the oil filler gasket? I'd like to order this off of parts.com so I dont have to deal with the stealership. Thanks in advance.
Old 04-21-2011, 04:45 PM
2508FJ's Avatar
CLK350
Man that was a lot of details for one post. Thanks for all the info.
Cheers
Old 04-23-2011, 01:40 PM
  #32
MTLdude's Avatar
2005 CLK 55 AMG
According to the new manual I bought the torque specs for the cyl head cover is 8nm for clk320 and clk 55 while clk 500 needs 10nm
The bolts for the coils to head cover are set at 8 nm for all models.
Very nice diy btw
Old 04-23-2011, 03:40 PM
  #33
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Very well put together DIY. Would be a must sticky I would think.
Old 04-26-2011, 12:19 PM
  #34
KyHusker's Avatar
2006 CLK 500, wife's is a 2014 E3504M
Great info, thanks!
Old 04-26-2011, 01:42 PM
  #35
MB Dave's Avatar
Suzuki Burgman Executive
I had my green filters cleaned, plugs changed, wires changed, oil changed, trans flushed (amsoil), diff flushed, and new inner and outer tie rods for my right wheel. My car drives like a champ.
Old 04-28-2011, 12:30 PM
  #36
Raffi007's Avatar
Great DIY
BUT you DO NOT have to open the valve cover , you can unscrew the spark plugs without opening the valve covers, the whole process will take you less than 45min.
I dont see why you say they should open the valve covers
I have changed my spark plugs yesterday in 35 min roughly and all great
Diamond Dave (04-01-2023)
Old 06-06-2011, 01:49 AM
  #37
s.pavel6's Avatar
2005 E320 4-MATIC
Do you know what size those E-Torx bolts are? I will need to buy a socket, and don't really feel like buying a whole set, would rather just get the right size Thanks!
Old 08-27-2011, 07:40 AM
  #38
Daca's Avatar
CLK 320
another smaller gasket there IMO
Excellent write-up.
I'm in the same boat, need to replace the gaskets, but noticed that oil actually leaks from another gasket which is from the smaller cover (green arrow) which sits on top of the one discussed above.
Is it possible that the leak comes from there?
Opinions please.
Attached Thumbnails DIY:  Remove and replace valve cover gaskets and spark plugs-3_111.jpg
Old 08-27-2011, 10:44 AM
  #39
Gersh320's Avatar
E320 & X166
Originally Posted by Daca
Excellent write-up.
Is it possible that the leak comes from there? Yes. Here is a write up from e55 but same principle:
https://mbworld.org/forums/w211-amg/...asket-diy.html
Opinions please.
I just changed my oil 1k ago. I will let it go the 13k based on the 229.5 specs. After that, I will replace my valve cover gaskets as well. Thank you for posting!!!
Old 09-27-2011, 12:28 AM
  #40
spinn's Avatar
2004 E500
Great write-up. Changed my sparkplugs on my E500 following this DIY. Don't know what car that one guy had that claimed to be able to change it all in 35 min; took me roughly 90 min to change out 16 plugs...only cuz I wanted to make sure I wasn't tweaking any plugs when I took them out. Definitely need to have the right extension for your spark plug socket to maneuver around the cover. Also bought a spark plug boot wrench off Ebay that made it simple to maneuver around the valve cover.
Old 09-27-2011, 01:48 AM
  #41
Black_CLK's Avatar
CLK 350
WHY ISNT THIS A STICKY!!!!!
Old 09-27-2011, 11:21 PM
  #42
MBworld Guru
Rudeney's Avatar
Received 1,003 Likes on 871 Posts
NO LONGER ACTIVE
Depending on the model, you may find it easier to get to the plugs from below the engine by removing the front road wheels and the inner fender shrouds. Here are photos from my W163:
ML320 Spark Plug Change
Old 10-20-2011, 11:55 PM
  #43
MShawCT's Avatar
CLK 55 AMG
Excellent write-up.
Opinions please.
I replaced the same side gasket a couple months ago. I also had a leak around the smaller cover. I was able to carefully pry the smaller cover off, clean both surfaces with a brush, and seal it with the same black sealant mentioned earlier. No more leaks. Just use caution when prying it off.
Now it’s time to do the driver side.
Old 11-30-2011, 08:55 PM
  #44
narunasalam's Avatar
2004 E320 4Matic Wagon
Inflexible or flexible fuel line
[QUOTE=SZMB;4228079]Yes, the left cover is only slightly harder because of the fuel line above the cover. There's no need to remove the fuel line, I just push it out of the way with one hand and jiggle the valve cover out.[/QUOTE
Is the fuel line you pushed out one of the flexible lines as on some models or was it the inflexible type shown in the write-up? Mine is an inflexible type and I would like to do what you did if it works for the inflexible line.
Old 11-30-2011, 10:02 PM
  #45
grane's Avatar
G350 Bluetec
Write up exemplar
Originally Posted by SZMB
I didn't find any leaks in these valves, connectors or hoses. They were clean. If they were clogged, they could be looking dirty. This is a California car, never been thru a cold winter, and I don't expect this car will have any problem w/ the breather valve. Maybe cars in the East Coast would experience clogged valves due to condensation from short trips during the winter months.
Given mileage >50k and years as a rule, based on my 113 engines, replace the hoses, breather gaskets, and other parts unique to the engine/car. Just because they don't look clogged or leaking if you are in there, might as well do all of it. Oh, if you can use a recommended washing solution for the valve covers, use it but make sure they are squeaky clean and chemically neutral before reassembly.
Props to your wonderful pictorial.
Old 11-30-2011, 10:04 PM
  #46
togaclk55's Avatar
CLK55
Hawt damn
Old 12-09-2011, 01:28 PM
  #47
dstoud's Avatar
2012 CLS 550, 2015 Q50S, 2007 CLS 550 (sold)
Great write up. How tight do the bolts have to be when putting the valve cover back on? What is the torque specs?
Old 12-10-2011, 04:01 AM
  #48
MLSYD's Avatar
2002 ML320 W163
Great post up!
I did mine today after i found oil on my spark plugs.
Unfortunately, when i opened it up the engine looked sooo bad (picture attached). Any suggestions how i should clean it?
I was hoping i can scrap most of it off and put the cover back on and let it run for a month then open it again to get the scrap the rest out.
Attached Thumbnails DIY:  Remove and replace valve cover gaskets and spark plugs-photo.jpg
Old 12-10-2011, 08:35 AM
  #49
Gersh320's Avatar
E320 & X166
Originally Posted by MLSYD
Great post up!
looks like the ford commercial!! When was the last time the oil was changed? looks like years. I don't think you will be able to clean that without removing all the parts and bathing it in some hard core solvents. With that much sludge, I would not be surprised if the camshafts, injectors, and other parts are completely shot. Good luck man.
Old 12-10-2011, 04:28 PM
  #50
MLSYD's Avatar
2002 ML320 W163
The last one was last month. Its like that because up until last year I knew nothing about cars and didnt know how often i needed to change the oil, sad i know, but since then i've been changing it every 6months. 12 months along there was some sludge where you pour the oil in and new oil would go down every slowly. With regular oil change it got better. I only opened it because there was oil on the spark plugs.
Removing all the parts isnt something you can do yourself or do i have to get the mechanic to do? if so, i can see how they're going to me heaps for it...
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
Quick Reply: DIY: Remove and replace valve cover gaskets and spark plugs
