Offset ET25? Rear
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Offset ET25? Rear
I got my new wheels 19"
my problem is the rear fitment...
265/30/19 19x9.5 ET35
my rear brakes are 4 pistons AMG = my new wheels hit my rear calipers
My question is: Did anyone tried 10MM spacer and drive with a Offset of ET25?
I know the standard is a ET30 but is ET25 acceptable?
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
I run 15mm on mine. I have heard them rub a couple of times on the highway going through those rolling dip downs at 65 -70. My wheels and tire sizes are the same as your post. Next spring I am going with 10mm instead on the rear. 10mm will be perfect. M
Info for the CLK owners:
I have installed the 10mm H&R spacers with the little lip.
with my 265/30/19 19x9.5 ET35 Rear wheels
soo I have a ET25 now and the wheels are at the right spot
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
1. Are you happy with the all around stance (are all 4 corners flush) or would a 10mm rear and 5mm front spacer equal out the flush?
2. Did you order extended (+10mm) wheel lugs from H&R or did you go with another brand/local?
Thanks!
04 CLK 320 > CLK32K
Wes, the wheels I've ordered are ET35 all around so I guess by the sounds of it I'll be going with spacers as well. Two questions;
Thanks!
Thanks!
Yea I had to get extended lugs. I have an extra set for sale that works with the 10mm spacer if you're interested. Ohh I bought them from the same person as the spacers. They say that H&R spacers come with the lugs but I was pressed for time and couldn't find anyone that sells them together.
If you have like me on the rear a ET35 wheel + 10mm spacer = ET25
then you need longer bolts (I now clear my 4 piston AMG brake):
You need:
Conical Lug Bolt 12mm x 1.50 RH Height: 65mm, Thread Length:
40mm, Hex: 17mm
Front:
And I have a ET30 on the front with no spacers with 225/35/19
(225 because I'm really dropped with PSS9) and I clear my 6 piston AMG brake
Front bolt:
Conical Lug Bolt 12mm x 1.50 RH Height: 54mm, Thread Length:
27mm, Hex: 17mm
Hope all the info is here for you next guys soo you have no trial and error
like I did
04 CLK 320 > CLK32K
To finish all the info on spacers...
You need:
40mm, Hex: 17mm
Front:
Front bolt:
27mm, Hex: 17mm
like I did
You need:
40mm, Hex: 17mm
Front:
Front bolt:
27mm, Hex: 17mm
like I did
Good info! My wheels actually needed the ball lugs. It's nice the you have ET30 in the front, mine is ET35 and I had to use a spacer to clear my brakes. Now that I'm on the PSS9's and 235 tire I am rubbing the front plastic fender liner on some turns. I will probably be switching to 225's next time around.
You need:
40mm, Hex: 17mm
Front:
Front bolt:
27mm, Hex: 17mm
like I did
You need:
40mm, Hex: 17mm
Front:
Front bolt:
27mm, Hex: 17mm
like I did
I'm happy with how it came out. I went with 10mm to make sure I cleared the BBK, and because anything less than that isn't hubcentric.
In regards to the lugs, I'm going to try and track down a set of chrome lugs to go along with the black wheels but thanks for the offer. If I can't find anything, I'll shoot you a PM.
19 C300
