CLK320 to CLK500 Calipers
Old Sep 9, 2010 | 12:51 PM
da_fantasie's Avatar
CLK 320
I have a 2004 CLK320. So my brake light just went on and I need to replace my rotors and pads. When I was at the shop, I was told I could get a set of used 2006 CLK500 calipers for fairly cheap. Since I'd be needing to replace my rotors/pads anyways, I was considering the switch. Please correct me if I'm wrong, but stock CLK320 rotors are 300mm, and CLK500 rotors are 345mm? I tried searching on the forum, but I'm kind of confused what rotors would fit the clk500 calipers? Are they the cross drilled ones? Would I be able to fit the amg ones?
Another option I was considering was getting the calipers/rotors from a SLK55 (from what I read it would fit my car). Could you guys please tell me how big the rotors would be, and how it would compare to the CLK500 ones?
Old Sep 9, 2010 | 01:57 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
The 320 comes with 300mm...I believe the 500 is 345mm...Stamped on the back of MB calipers is the size of the correct rotor. I can't comment on anything else, but I could say I'm running 355mm with no problems.
Old Sep 9, 2010 | 02:21 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Found this link, very informative...
http://www.mwstewart.co.uk/articles/w209sportbrakes/
Old Sep 9, 2010 | 04:24 PM
CLK 320
Thanks so much. That's a really informative article and exactly what I was looking for.
Old Sep 10, 2010 | 02:38 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
No prob
Old Sep 13, 2010 | 03:32 PM
CLK 320
Could someone please clarify the differences between the CLK55 (4 piston) vs the CLK500 (4 piston) brakes other than the rotor size?
According to the article, it seems like the CLK500 rotors are 350mm, compared to CLK55 which are 345mm. As well, when I checked parts.com to compare the prices for 2004 CLK parts, the CLK500 calipers are more expensive than the CLK55 calipers.
I realize in later years, the CLK 55/63 has 6 pistons, but I'm curious to the difference in performance before the upgrade.
Thanks.
Old Sep 13, 2010 | 04:46 PM
bheng's Avatar
2003 CLK 320
r1concepts is telling me the clk500 and 55 share the same rotor.
Old Sep 13, 2010 | 04:47 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Does pre/post facelift make a difference?
Old Sep 13, 2010 | 04:56 PM
CLK 320
If the rotors are the same, then what difference is there with the calipers? It's just parts.com prices the 500 calipers almost double the price of the 55's.
Old Sep 13, 2010 | 05:12 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
What year 500 & 55?
Old Sep 13, 2010 | 05:16 PM
bheng's Avatar
2003 CLK 320
nope. all the same rotor for the 4 piston from 03 to 09
i dont know what to say about this one. from my understanding, both 500 and 55 pre 6pot brakes used the same 4 pot. except one had AMG and the other had Mercedes benz written on it. and possible a size difference .
so i dunno why. if you looking to do a conversion, i would say either buy a set of used 4 pot brakes or go 6 pot which would be hard to find or you can do a bbk from stoptech or brembo.
4 pot brakes come from many cars, so your gonna have better luck getting them.
Old Sep 13, 2010 | 05:22 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I know that this doesn't make a difference but all MB calipers have the rotor size number by the mounting points..
Old Sep 13, 2010 | 07:00 PM
bheng's Avatar
2003 CLK 320
i didnt know that... ima take a look next time i take the calipers out of the box. ha
