Quad ///AMG Tips and Diffuser Installed on a CLK500
Either black or grey (to match the seats), perhaps do the dash and other surfaces too (any suggestions). If I go H&R Springs, what spring pads do I use to make the drop even front/back (V8 Engined W209)?
hey in new on this but im about to do the quad exhaust on my w209... do you have any video of your exhaust to hear the sound..i am trying to decided on 1 or 2 resonator's with the exhaust..send me any helpful information you can..thankss
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
#5 pads? There is a thicker pad than the 17mm #4? What's the thickness and part number (if you have it handy)?
#34
The more resonators you add to the system, the quieter it will be.
#35
As you can tell-from my other bumps-i'm really trying to figure out what system to run. I like Kilh's system but i realized today that on a cold day, the exhaust might look a bid odd. So i'm debating if i should do this set-up (perhaps with a quieter muffler) and add my oem bubble silencers before the tips.
#37
#40
#41
04 CLK 320 > CLK32K
Not sure, but I could tell you he didn't get one for the other side. You would have to switch the spare wheel well to fit the OEM heat shield on the right side. I imagine you could have one made though.
#42
You think i'd need a heat shield if i'm just sticking the two oem silencers that came with the car (one on each side)?
#43
04 CLK 320 > CLK32K
You should be fine. You're going to put them on each side of the spare wheel well? It might be a PITA to secure them to the car. Why not run them in the center and straight out to the tips?
#44
So muffler, two bubbles silencers and then pipes? I can do that, i just figured having the silencers a bit after the muffler would keep the noise down a bit? I love 2MCHCAR's set up as it's a true dual without the cost of a true dual, i just don't want it to be loud.
#46
BENZ 550
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
#47
#49
Damn man...
From what i get you want the diffuser that you see on Dyno's car
VISracing.com has that diffuser. You need a AMG rear bumper though for it to fit.
