Window noise
Old Oct 19, 2010 | 10:57 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Window noise
Dis any of you had/ have problem with there W209 coupe windows...?
I ajusted my passager side window at the dealer last spring (the window
was loose when opening and closing the door) = now at 100mph I have a
wind sound that the dealer can not fix )
Now it's my drivers side, becomming loose and make a sound like rubbing
on the rubber seal (like it's not lubed...) you I put some KY ? !
Eveything is great on the car exempt those stupid windows
Any you guys have this? repair?
thanks, like always
Old Oct 19, 2010 | 11:12 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
I found a few threads on this hoping that I would get around to lubricating the rubber seals eventually. I also have a list of MB lubricants in the parts sticky
https://mbworld.org/forums/clk-class...dow-seals.html
Old Oct 22, 2010 | 10:45 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
This kit is specially developed and tested to be compatible with MB's. You can order the lubricants individually or as a whole. The prices are off parts.com
002 989 0651 - Lock Cylinder grease $10.35
002 989 0751 - Mulitpurpose grease, Metal $42.55
000 989 3860 - Special sliding compound, Grease $82.80
000 989 3560 - Special sliding compound, Spray $20.70
000 989 3760 - Special sliding compound, Dispersion $48.88
000 989 3660 - Special sliding compound, Liquid $29.33
000 580 03 50 - Noise Damping Service Kit $189.75
Old Oct 25, 2010 | 09:30 AM
FatTony001's Avatar
good find. thanks !
Old Oct 27, 2010 | 02:55 PM
pcardoza's Avatar
2006 CLK350 Cabriolet
Diddling with window adjustments almost never leaves you happy. If the dealer can't fix it, try another one or surrender.
