How to silence the rubber window seals???
The rubber window seals on my coupe are noisy especially when going over bumps or up an incline of a driveway etc, any cures?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Best regards,
Matt
2010 ML350 CDI AMG Sports, BMW e92 335i (sold), CLK240 Avantgarde (sold)
I also get the noise but mine only makes that noise whenever I drive off after the door has been opened and closed... at one stage my dealer put some clear grease on the window seal but I hated it because it left quite an ugly residue behind so at the moment I've just put up with it but I think some clear grease is the way to go...
Cheers.
Thanks for the tips...I read somewhere on this site that there was a specific product for this issue, anyone out there remember what it was? I know that there is a dry silicone spray that might be better than the regular stuff.
I seem to be getting the noise from the rear, drivers side window, lower insiderubber seal in addition to the normal front window upper seals noises.
Originally Posted by bryanm
This is a known warranty issue - interior squeaking/creaking noise kit (TSB P-00-45-77).
Yes, mine was done - it took them around 3.5 hours (according to the bill).
It did involve removing the panel. The technician did an excellent job, you can't tell that anything was done.
The alternative, sparying in a bunch of goop, is likely a short term messy fix if it works, and if you want the warranty fix later they may refuse claiming you caused the problem yourself.
I tried some silicone spray on a cloth and did all the window seals and strips about 4 times over a 7 day period, I figured I had nothing to lose since I was going to bring it in for this and my squeaky brakes, well after the third treatment the noise is almost completely gone and the car's been washed twice too. I still think the new gaskets are the best and most permanent solution but I'm pretty satisified now and can rest easy some incompitent or hurried tech doesn't ruin or stain the panels etc that need to be removed to access the rubber seals.
I did in fact find a dry silicone spray is available but you need to look hard to find it or ot can be ordered on-line if you do a search, I used the regular stuff as it dries quickly and does not leave a greasy residue.
Now if I can only get the brakes to stop sqeeling at low speeds I'd be happy, the problem is it's an intermitent noise which the dealer loves to say CANNOT VERIFY, but the first 5 minutes when you leave the service dept on the way home the noise decides to say hello.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Originally Posted by Psycho
Could you check this number again, because my service department typed this code into the STAR system, and could not locate this TSB. Is it possibly for another model?
Thanks for the tip about the dry silicon spray, have noticed my car is starting to make the noise under acceleration and over speed humps.
Originally Posted by kaiju
If only Merc can make a car with no faults
Back to the problem at hand. Biased somewhat because I had it done already - I prefer the replacement felt method to the band-aid spray solution. The spray will disapate over time and hopefully the felt is there to stay.
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Seems in spite of a very ridgid CLK frame/body, going over some speed bumps or MB service managers will cause window rubber squeaking noise.
Coming out of a Porsche, owners had a somewhat similar problem. The noise instead was caused by the windshield rubbers making noise while going over a bump.
The real fix was accomplished with a solid lubricant called Pedro's Ice Wax. Apply Pedro's directly to the rubber weatherstripping across the contact area. It is waaaay better than silicone and it lasts. It does not stain either.
You can buy a small 2 oz. amount for only $1.98. Larger 1 gallon sizes available if your Cat D9 blade is also squeaking.
It is available at better bicycle stores.
Here is a quick web link:
http://www.pricepoint.com/detail/113...-offerIN050DW1
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Awesome! thanks dude!
CL500 (W216)
CLK200 kompressor, BMW X3 2.5i, BMW525i
I had this creaking noise for a while coming from the back and I guessed it was coming from the windows so i took the car to the dealer he listen to the creaking and he told me that the windows needed readjustment (whatever this is) but nothing about lubricants. So i took the car back but when I accelerate from stop here it goes again (i also here the creaking when i drive on rough surface or over bumps). Do the windows need lubricant and if yes where and how you apply it? Is it better for the dealer to fix it?
209/W210 Estate /W211 modded by MBENZNL
When I Worked for Mercedes we Used the Special Lube for the Pano Roof on the 209 window seals...clean the seals then apply the lube with a Q-tip..Seems to last...I Did My Sons New 2007 209 and it no longer squeaks
