Headlight fitments question.
#53
Question?
When you guys changed your headlights did you still use the same HID bulbs and ballasts?
Did you leave the stock ballast in place or removed it? What about the ignitor and other cables?
#54
04 CLK 320 > CLK32K
The Bix's have their own bulbs and the ballast is located on the bottom I believe. You will probably have a stock 4300K bulb in there. All you have to do is switch out the bulb to the temp you want. You are going to want to take your hid kit out, no longer necessary.
#56
04 CLK 320 > CLK32K
You can't use the aftermarket bulb because the model of the bulb changes with the Bix. I believe the model is D1S. Did your lights come with bulbs? I bought mine from Hidextra for like $90.
The first pic is the stock 4300k D1S bulbs my BIXs came with, the scond is the 6000k bulbs I ordered from hidextra.
![](http://i852.photobucket.com/albums/ab82/Dynomite05/DSC00270.jpg)
![](http://i852.photobucket.com/albums/ab82/Dynomite05/DSC00271.jpg)
#57
05 CLK500; 07 Volvo XC90
I will ask him tomorrow about the window when I take the car back for him to readjust the light height level. Out tonight, I noticed one light is a lot higher (or maybe lower) than the other one.
Also, I am curious about the 'bixenon' feature. When I flick my hi beam stark, the inside (non-projector) light comes on (just like when I had the halogen) and that light bulb is just a regular bulb. I thought bixenon (at least on my XC90), the hi beam and low beam are on the same projector.
Could it be that only xenon fitted from factory can do the bixenon feature. Anyone here check out the working of their xenon lights?
#58
Yes mine came with bulbs but its prob that white stock color which i dont like.
I hope they have the D1S in 8000k iceberg blue.
Thanks for clearing that up i was getting confused.
#59
My headlights came of a 2003 CLK320 so my bulb is actually:
2003 MERCEDES-BENZ CLK (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
and only cost $30 at Hidextra. Niiice
Low beam headlamp
HID-D2S
#61
yes sir
http://www.hidextra.com/d2s-8000k-hi...404d5a395dc4b2
i will have to test my ballast first if it is working or not than buy these.
I was looking on ebay and those ballasts do run expensive
#63
04 CLK 320 > CLK32K
If you got that info from sylvania, it's wrong. Don't make the same mistake I did. Check your bulbs in the lights. If they have a square base they are D1S, if they have a round base they are D2S.
#64
04 CLK 320 > CLK32K
yes sir
Why wouldn't your ballast work?
#65
04 CLK 320 > CLK32K
You should be able to adjust them yourself. I believe Klinh has a thread with pics. I will see if I could find it.
#67
Yes i just bought my headlights and am waiting to install
I did get it from Sylvania. I checked the bulb and it is indeed D2S
Well considering this is a 2003 CLK they came off from i am not sure if the ballast is near to an end. Not sure how long Mercedes ballasts are supposed to last
#68
Andy
#69
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Here they are ...
They also fixed my driver window rattled when slammed close. I thought it was like that since it is a pillarless window. They fixed it and now no more rattle when closing.
They charged me $180 for headlights installed and xenon activation. $60 to fixed the window. They said the window regulator would have cost $500.00.
#70
you wouldn't use the D2S ballast for the D1s bulb because D1s has the ignitor
built in integral with the bulb base (the large squarish thing). this improvement
in design negates the high tension lead between exterior ballast winding up to
the bulb....a potential cause of EMI...and resolves other electrical gremlins.
#72
2011 E550 Sedan
#73
yeah but they dont match with the city LED lights.
I was wondering how the city lights would look after painting the reflector black though. Probably not much projection... I might remove them not sure
#74
