Common Problems with CLK500
Old 01-12-2011, 12:49 PM
mig1980's Avatar
2003 SL55, 2006 CLK500, 1998 Vette
Good day everyone. My 2006 CLK500 warranty is about to expire in a month. The car really has no problems that I see. What are the most common issues with these cars and what should I have replaced under warranty before it expires?
Any help is greatly appreciated!
Old 01-12-2011, 12:59 PM
kostas86's Avatar
V8, Flat 6, V6, & Turbo flat 4
The only thing I have seen that tends to go out (some people may disagree) are the alternator, power steering pump, and make sure to check your tranny for any issues.
Old 01-12-2011, 01:01 PM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Something common that I noticed was an issue his the electric headrests, the switch seems to fail on quite a few CLK's. A couple of TCU's as well.
Old 01-12-2011, 01:22 PM
M-bENZ's Avatar
Corrolla
Seats module, Maf sensor and valve gasket thats all i can think of it right now...
Andy
Old 01-12-2011, 03:59 PM
Bob Loblaw's Avatar
2005 CLK 500 Cabriolet
Dealer replaced the rear seal on my engine last time I was in.
Old 01-12-2011, 06:00 PM
BadDebt's Avatar
2008 ML550 P2. 2010 E350 P2
Stepper Motor as it relates to the A/C
Old 01-13-2011, 09:42 AM
2MCHCAR's Avatar
Supercharged CLK500 & ML500
I've replaced under warranty:
  • AC Stepper Motor
  • Rear Seal
  • Valve Gaskets
  • Transmission Plug (harness going into the tranny leaks oil)
  • Seat Warmer
  • 3rd Brake light
  • Engine Motor Mounts
  • Tranny Mounts
  • Seat belt Mechanism (that pulls the seatbelt back in)
  • Removed that damn "SOS Malfunction" indicator
  • Various Suspension bushings
  • Headlight Xenon ballast
  • Windshield wiper adjustment
  • Sunroof adjustment
Old 01-13-2011, 01:00 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
i had to replace myself (no warranty)
driver side HID ballast
Amp (this was a PITA because only OEM will work because of the digital optical lines)
3rd brake lights *(cracked)
Old 01-13-2011, 01:07 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
How much was the AMP to replace?
Old 01-14-2011, 08:30 PM
M-bENZ's Avatar
Corrolla
  • AC Stepper Motor how do u know that you need to change ?
  • Rear Seal what is this ?
  • Valve Gaskets
  • Seat Warmer
  • 3rd Brake light
  • Tranny Mounts
Could you answer the questions above ? I plan to go to the shop on Monday to inspect everything.
Old 01-15-2011, 01:30 AM
billyhead1's Avatar
CLK 320
- Trans mounts: feels like trans is slipping and takes more revs to get the car to take off. Replaced on my CLK...under warranty thank goodness
- RMS - Rear Main Seal - seal around the flywheel end of the crank. Leaking oil out the rms means slippage
- MAF - mass airflow sensor - common problem area, yet havent had any issues with my clk
- radiator - make sure you have the Behr radiator vs. the Valeo. fluid contamination makes the tranny go boom.
- trans - make sure yours has had the fluid drained and replaced, every 40k. TSBs from the dealer indicate that you should drain/replace (not flush) trans fluid every 40k. when these cars were new, it was "lifetime" fluid. all i can say is do it. that leaky seal is cheap to replace. do that too. done on both my c sedan and clk
- power steering: seal/o-ring in the plastic resrvior fails, causing fluid level to drop. ultimate solution as I understand is to replace reservoir and seal. make sure to check the PS fluid (it is special MBZ hydraulic oil - $30/liter) as it is one of the only things NOT on a sensor in our cars
That's all I can think of...Wes?
Old 01-15-2011, 02:14 AM
M-bENZ's Avatar
Corrolla
Thanks billy but how about the AC stepper motor ? how do i know that i need to replace ?
Andy
Old 01-15-2011, 12:13 PM
2MCHCAR's Avatar
Andy
When you hear loud "thunks" coming from behind the dashboard, when you startup your car.
I also forgot to mention the CPS, that goes out too. Your car will have trouble starting up and the engine will experience hesitation while driving.
Old 01-15-2011, 01:13 PM
tru350z's Avatar
CLK500
Hello guys, newbie here
Just bought 05 CLK500 w/ 47K miles and like it so far.
Just wondering, how many miles on your CLK's? Seems like it has many common problems.
Old 01-15-2011, 01:16 PM
Kevwood's Avatar
Yes it does, you're doomed!
J/K, everything on the road has issues now and then, my Benz's are still the most reliable cars I've ever owned, keep them maintained, they'll be good to you.
Welcome to the board.
Old 01-15-2011, 01:20 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Old 01-15-2011, 01:43 PM
tru350z's Avatar
CLK500
Thank you.
Not to high jack your thread OP.
Just reading up on other stuff on CLK and came across w209world. Very good web site with info.
I may have issue with my tranny. Here is direct quote.
"The 7-speed automatic transmissions can have problems with internal component failure that cause rough shifting going up from first to second gear and going down from third to second or second to first gear. Mercedes released updated parts; the transmission will need to be removed and disassembled."
I wouldn't say real rough down shifting but i can feel down shifting from 2nd to 1st gear. Is that normal? Would it fix with tranny oil drain and refill?
Old 01-15-2011, 02:02 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Yo have 7spd in your 05?
Old 01-15-2011, 02:05 PM
tru350z's Avatar
CLK500
Isn't it standard on 05 CLK 500? I may have 6sp but i can feel down shifting from 2nd to 1st gear on braking.
M-bENZ's Avatar
Corrolla
61k at the clock right now the car is fine i just wana check up for everything while it still under warranty. I too have the 7 speeds.
Edit: You should have 7 spd from 05 + up.
Andy
Old 01-15-2011, 02:10 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Do you have a maintenance records for the car?
Old 01-15-2011, 02:15 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Thank you.
That quote is only for the 07, 08, 09 550s.
Old 01-15-2011, 02:27 PM
tru350z's Avatar
CLK500
I don't have maint record. From my understanding it needs new tranny fluid.
It shifts up and drives fine but only on braking. I can feel gear down shifting applying engine brake.
I guess quote is for 07 and up 550's but i have similar issues, thought i should ask.
I couldn't find Tranny DIY thread yet. . .
Old 01-15-2011, 03:14 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I believe a tranny flush is recommended every 30K miles, so you're probably due for one. Do you have a warranty on the car?
Old 01-15-2011, 03:20 PM
tru350z's Avatar
CLK500
Unfortunately no.
I didn't see tranny oil dip stick from engine bay when i change engine oil. Are the fill and drain hole in tranny pan?
BTW thanks for your help.
Quick Reply: Common Problems with CLK500
