keyless go exterior door handle problems
Old 01-16-2011, 04:38 PM
henry47's Avatar
asdf
sometimes my car cannot recognize my key but its only my driver side door. il walk up to the car and pull the handle and nothing will happen.
I took apart the door handle to make sure the connection was good and there seems to be no connection problem.
I'm thinking I should replace the exterior door handle from parts.com but am trying to think what else could be causing this.
I don't want to buy a new door handle then realize later that it was something else and have a spare handle laying around.
I'm not sure if its the sensor or handle.
can anyone tell me if I buy the handle on parts.com is it only the handle or the sensor also?
on parts.com the part number is 21176011709040.
Old 01-16-2011, 04:42 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I don't have access to the EPC, but I could check for you tomorrow.
Old 01-16-2011, 04:59 PM
henry47's Avatar
asdf
awesome thanks dynomite. I think this is like the eighth time you've helped me out. I appreciate it a lot.
do you think replacing the external parts would solve my problem or can you think of any other reason why this would be happening?
Old 01-16-2011, 05:06 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
No prob. Honestly, I'm not sure if it will fix the problem. I'm waiting for my new copy of the WIS to come in so I can't look up that problem. Do you have a warranty, or and Indy shop you could pass by and speak to?
Old 01-16-2011, 05:15 PM
henry47's Avatar
asdf
nah no warranty or independent shop I go to. my buddy had a similar problem and he had his fixed under warranty. he said they just replaced the door handle. I hope its as easy as that and not electrical problems
Old 01-16-2011, 11:23 PM
dragon_27's Avatar
03 clk500, 06 qx56
hey i have the same problem right now. the driver's doesn't sense the keyless entry, but the passenger side does. so i wanna know the same question, if i need a new door handle or if its the keyless go sensor module or something...
Old 01-17-2011, 02:28 AM
henry47's Avatar
asdf
i guess once dynomite tells me if its a 2 piece set, ill order it and ill give it a try.
i don't know though, cuz im having problems with the passenger side door sometimes too. not as often as the driver side though.
Old 01-17-2011, 12:10 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Ok, so I used a CLK63 to access the Keyless-go options. Looks like you the part number you have is the same except for the last 3 digits (color code). The code for keyless-go is 889. There are 2 parts, besides the locking mechanism itself, that are keyless-go specific and coded with 889. The handle and what they describe as 'bearing'. From the looks of the diagram, I don't see the sensor being separate from the handle. Not sure what the bearing is though.
Old 01-17-2011, 01:33 PM
henry47's Avatar
asdf
from your picture, i know i need part 200 and part 250, as that's where the sensor is. the other parts I can reuse.
So it looks like the part number I gave you comes with both these parts?
edit: nevermind, i looked up the part number on parts.com for item 250 and it's a separate charge.
shucks.
I guess I'll order the door handle first and see if that'll fix it
Old 01-17-2011, 01:38 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Yea, they are separate #'s. Good luck man.
Old 01-17-2011, 01:53 PM
henry47's Avatar
asdf
dynomite, can i ask you one more question while you're here?
my gf has a 2004 c320 with black interior. her front passenger door handle broke off somehow and I'd like to replace it.
can you tell me the part number for this in black please? (but front passenger)
Old 01-17-2011, 01:55 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
For a specific part like that, it would be easier with a VIN. If possible, PM me the VIn and I will get it for you.
henry47's Avatar
asdf
awesome, thanks a lot
Old 01-26-2011, 10:57 PM
henry47's Avatar
asdf
update:
so i ordered the new door handle and installed it this afternooon. it SEEMS to have fixed the problem but am still not sure as sometimes the problem comes up every few days.
i'll let you guys know how it goes.
btw, i paid $140 from parts.com for the part FYI
Old 01-27-2011, 02:59 PM
dragon_27's Avatar
03 clk500, 06 qx56
so you changed both door handles? how easy was the install?
Old 01-27-2011, 03:03 PM
henry47's Avatar
asdf
I only changed the drivers side handle (with button, not sensor with key hole).
I took apart my door handle several times before so it only took me 3 minutes to do it, but the first time it took me almost 45 minutes as it's quite tricky. if you try it, i can give you step by step instructions on how to make it easier and save you some time.
Old 02-23-2011, 08:11 PM
dragon_27's Avatar
03 clk500, 06 qx56
hey can you give me step by step instructions and also, the exact part number to the door handle? on parts.com, i'm not sure which part it is to order. i was at mb and they said its not the sensor, just replace the door handle for my problem because the passenger side still opens when it senses me...
Old 02-23-2011, 09:05 PM
henry47's Avatar
asdf
you'll have to contact parts.com customer service in order to be put in contact with their mercedes parts distributor. i believe his name is joe. you'll have to give him the vin number of your car so he can loook up the part number for you.
so i'm 100% sure that this has fixed my problems as I haven't had any more problems with my driver side door not recognizing my key.
as for explaining how to replace it, i believe if you search, dynomite has posted it when i asked him a few months ago. let me know if you have any problems (especially with putting the handle back in. taking it off is SUPER easy and only takes a matter of a few minutes)
Old 02-24-2011, 10:45 AM
Yidney's Avatar
2008 CLK550 Cab
When this happens, is there a message on your cluster that says "key not detected"? What you describe has happened to me only twice, and I happened to notice this message on the dash when I tried to open the door. The last time, I took the key out of my pocket and then it worked. I need to experiment if it happens again, but it made me wonder if something else in my pocket was interfering with the signal, like my elevator key card.
Old 02-24-2011, 11:16 AM
dr_npz's Avatar
09C63AMG, 03E320
Try to change your batteries, that should help. If a message comes up on your cluster, that means the handle is working.
Old 02-24-2011, 11:39 AM
Yidney's Avatar
2008 CLK550 Cab
I should have mentioned the batteries were brand new in my first post. Always a possibility of bad battteries I suppose. Anyway, I will experiment if it happens again and report back if I figure anything out.
Old 02-24-2011, 11:50 PM
dragon_27's Avatar
03 clk500, 06 qx56
ok thanks
Old 02-25-2011, 09:46 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
I had about the same problem with mine last year... some times the door
would open , sometimes not.( does not reconzise)
I replaced the battery in the key. then BAM ! all is good 1 year later
Old 03-01-2011, 02:11 PM
dragon_27's Avatar
03 clk500, 06 qx56
hey after installing the new door handle, does it need to be reprogrammed or anything so it can sync in with our key fob? so once the car is locked and you wlk to it, and open the door, it will unlock, right? cause it senses the key remote?
Old 04-26-2011, 05:41 PM
dopeclk's Avatar
2004 CLK 320
Can u pm me instructions on how to apart the door handle. Thanks
Quick Reply: keyless go exterior door handle problems
