no bass in stock speakers after sub install
Subscribe
Jan 27, 2011 | 11:24 PM
anyone have this issue?
I have 0 bass in my satellite speakers after I installed an amp and sub my clk
went back to the installer who said he didnt have anything to do with that??
Reply 0
Jan 28, 2011 | 06:58 AM
So, you are running the factory head unit and the factory amp for the door speakers and an aftermarket amp and aftermarket sub as well?
Reply 0
Jan 28, 2011 | 08:43 AM
Your stock head unit may be putting too much power out to ur sub cause ur sub amp requires it. sucking power away from your front components. I assume ur using a hi lo converter?
Reply 0
Jan 28, 2011 | 08:57 AM
Quote: Your stock head unit may be putting too much power out to ur sub cause ur sub amp requires it. sucking power away from your front components. I assume ur using a hi lo converter?
Reply 0
Jan 28, 2011 | 09:17 AM
Not sure what a hi lo converter is...just had it installed by a pro
The way it's routed...the sub has it's own knob
When i change the bass setting on the factory hu
It turns up the sub bass only
Reply 0
Jan 28, 2011 | 09:57 AM
Pull the fuse on the sub amp, then listen to the door speakers turning the bass on the head unit up and down. Report back...
Reply 0
Jan 29, 2011 | 12:46 PM
No change in the bass of door speakers
Reply 0
Jan 29, 2011 | 12:51 PM
Put your ear to the door speakers. Are they playing at all?
Reply 0
Explore
Jan 30, 2011 | 01:46 AM
no bass playing in the door speakers at all...
definitely there was bass there before?!
Reply 0
Jan 30, 2011 | 10:29 AM
Okay, so you disconected the aftermarket sub from the system by pulling the fuse and now while playing just the door speakers and adjusting the bass all the way up there is no change in the sound whatsoever? Is this correct?
Reply 0
Jan 30, 2011 | 11:21 AM
Yes this is correctp
Reply 0
Jan 30, 2011 | 12:18 PM
You know what I just did for you mate? I went outside, popped the sub grill, disconnected it and listened to the speakers - virutally no bass.
The HK crossover system is cutting all the sub bass (and a majority of the mid bass) out of the door speakers. You probably thought you heard more bass in the speakers because the factory sub is cabin firing and is more of a fill in sub rather than a shake your klingons loose sub.
I presume that you have an aftermarket sub in a box in the trunk now and the factory sub is disconnected...?
Reply 0
Jan 30, 2011 | 08:34 PM
Quote: You know what I just did for you mate? I went outside, popped the sub grill, disconnected it and listened to the speakers - virutally no bass.
I can confirmed that when u disconnected the stock sub you not going to hear any bass at all .
Reply 0
Jan 30, 2011 | 09:00 PM
Thanks so much!!
I had no idea i had a factory sub !!!
Yes I have a rockford Fosgate 12" t1 with Rockford Fosgate 500 monoblock amp
Reply 0
Jan 31, 2011 | 12:38 AM
How powerful is the stock sub?
Btw it was a
Close call between JL 12" w6v2 and the t1 Fosgate
But heard side by side Fosgate seemed to hit harder for hard rock and trance
Reply 0
Jan 31, 2011 | 01:42 AM
I don't know what the exact wattage is for the factory issue HK sub but it does do a nice job as fill. The loaction in the rear deck (cabin firing) and the free air design work pretty well as it goes. One day, when/if I finish the other dozens of projects I have on the go in the car and around the house I'm going to put a system in, I plan on mounting the subs in the rear deck. We'll see.
Reply 0
Feb 1, 2011 | 03:43 AM
Thanks for then info kev
Quick comment
For some reason I don't have those 2 hole ports in my back seat...I'm wonder what hk system i have
I got the p2 package will check the sticker
Reply 0
Feb 1, 2011 | 04:31 AM
Quote: Thanks for then info kev
Quick comment
The sub ports came on the cab, the coupe has the cabin firing set up, w/ out the ports.
Reply 0
Subscribe
Currently Active Users (1)
