Question re transmission modes
Old Jan 31, 2011 | 10:41 PM
JoeBloggs's Avatar
2007 CLK 550 Cab
Does anyone know if the two different transmission modes (C and S) "learn" driving style independently of each other? I've carefully trained C mode into granny style driving - quiet, smooth, and good mpg. Does that mean I've also trained S mode into granny style? Or can I teach S mode to be more aggressive without changing what C mode has learned?
Thanks in advance!
Old Feb 1, 2011 | 04:36 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
I'm quite positive they follow the same pattern of learned driving style, just the S starts in 1st and is more eager to changes gears, C holds the gears longer. When I switch between the two it's not much of a difference, after re-setting the ECU both reset and are similar again.
It would be fantastic if C was a learning setting and S stayed closed loop and crisp all the time but that isn't the case.
Old Feb 1, 2011 | 01:29 PM
JoeBloggs's Avatar
2007 CLK 550 Cab
As you say, a shame. Oh well. And thanks for your input.
Old Feb 1, 2011 | 01:35 PM
kostas86's Avatar
V8, Flat 6, V6, & Turbo flat 4
I have not noticed a HUGE difference between the 2, just shifting points.
