New Jamesbbh's CLK500 cab thread
#351
2006 Facelift CLK500 Cab-
ok:
Before
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep001-6.jpg)
Corners
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep004-7.jpg)
The instructions say it helps to have 3 people (which I totally agree with) but I usually work on things by myself so I had to improvise. I spent probably 30 minutes just making sure everything was perfectly lined up.
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep006-6.jpg)
Started drilling holes and inserting screws with lip still taped and took tape off as progress was made
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep007-6.jpg)
TA-DA
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep009-4.jpg)
Before
Corners
TA-DA
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep010-5.jpg)
#356
#359
N/M I got it figured out, I re-ran my power wire for the amp through all of the factory wiring routes so you can't even tell there is a power wire at all even with the backseat out now. It just took some wire coat hanger magic and of course:
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep015-2.jpg)
#360
Found this plug and took it out of the firewall
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep014-2.jpg)
Crammed 2 gauge through via vaseline (I felt like I was violating the car a little)
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep013-2.jpg)
Removed seatbelt/side panel/backseat and followed the factory plastic "tunnels" all the way into the trunk. The power wire is invisible unless you know it's there now.
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep016-2.jpg)
#361
Oh and the reason I was wondering is because the factory wires go through a metal box of some sort in the trunk that I think protects the hydraulic motors/lines for the top and I was wondering the location of whatever was inside it lol.
#362
So this weekend included the following:
- Got my compressor motor fixed (ended up being the start Capacitor)
- bought and re-wired a cutmaster 42 plasma cutter to be operated by hand instead of the cnc table the guy had it on
- semi- plumbed a temporary air system (it meets my demands right now but if it starts falling short I'll do everything bigger)
Dessicant dryer-->oil/water seperator-->filter/regulator-->another filter-->plasma
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep021-1.jpg)
It works!!
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep022.jpg)
I officially love this thing by the way.
It works!!
#363
If you look at the "T" I have one regulator filter followed by a shut off valve then an inline oiler for air tools that require oil and the other way I have a shut off valve leading to another filter/regulator with no oiler for the plasma.
![Rcain](https://mbworld.org/forums/images/smilies/rcain.gif)
![Boink](https://mbworld.org/forums/images/smilies/boink.gif)
![Wootrock](https://mbworld.org/forums/images/smilies/wootrock.gif)
#365
Mercedes CLK 320 W209
#366
#368
Thanks Wes! Last night I plumbed the extra 30 gallon air tank I have into the system getting fed from the bottom of the tank and out throught he top to help with catching water as much as possible. So now the compressor fills up the 60 gal-then the 30 gal- then you have more of a "working" time worth of compressed air without the compressor trying to catch up.
#369
My buddy Joey came in for the weekend and wanted to see how the plasma worked and I wanted to try out my new magnetic ground clamps I got for the plasma/welder so naturally we killed a bunch of beers and this ensued
3/16" steel
3/16" steel
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep024-1.jpg)
#371
#372
Did a little work on the mini-trailer. Got the jeep rear bumper mounted and some "just in case" plates welded to it.
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep026.jpg)
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep025.jpg)
Oh and tyrone had a stare down with my buddy's chihuahua
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep028-2.jpg)
It's obvious who won that one
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep029-2.jpg)
#375
Got soem KC daylighters for $20 on C/L (normally around $200)--made some brakets--mounted them (still need to paint the bumper though) and went to the beach and parked next to this celica haha
![](http://i467.photobucket.com/albums/rr31/Jamesbbh/CarJeep036-1.jpg)
