Looking to buy clk500 2003 tomorrow HELP! ADVICE PLEASE!
09 C63 AMG, 05 C55 AMG
Hey there,
I am going to look at a 2003 clk500 tomorrow, and possibly purchase it.
Any problem areas or things to inspect or look for? common wear items?
besides looking at paint, body, oil gunk buildup in cap, rotors, pads?
Carfax/autocheck is clean, 98k miles. Car is under warranty.
any advice is helpful, as I am only familiar with c32 amg's and their common problems
2004 W209 CLK500 Convertible
Pay for a pre-purchase inspection. I spent $140 for the peace of mind that I got a good car. Make sure you have extra cash if a part falls off, maintenance is $$$. I bought a CLK500 4 days and LOVE it.
The whole 14MPG might get old. I thought the radio was crap, but the EQ was messed up and now it sounds great.
Best thing you can do is to look for standard things that you mentioned but taking for inspectiowill save many headaches later. Make sure trans oil has also been taken care of and does not look for pitch black. Waiting till 100k is not the best thing. Listen for knocks in suspension when going over bumps at low speeds. And make sure all electronics work. Check every button.
03 clk500, 06 qx56
yeah definitely get everything thoroughly checked out. my 03 clk has had problems such as transmission leak, engine mount, thrust arm, seatbelt, a/c, sway bar, and now the heater system and catalyc converter...
2018 E43 | 2017 GLS450 | 2004 CLK 500
If the transmission has not already been replaced, If it were me I would get an extended warranty if possible. I'm told that the 03 transmission which was used on the w208 had some issues (mine went out at 30) and was redesigned for 04. So it will go out at some point.
Signed the papers with the premise of them getting that looked at for me, and it turned out they had to replace the electrics in the transmission and have it re-coded at a cost of NZ$3500. I pick it up on Friday.
