Help please....Removing Cd Changer 2003
Old Feb 25, 2011 | 08:37 PM
forhim's Avatar
2003 clk500
I am trying to send my cd changer in for repair. The ole No Magazine error. I've been told laser not working. Here's the problem, do you have to remove the center console to take out the changer. We can't seem to find how to get the left side out of the bracket in the glove box.
Any suggestions will help. Also can the cd changer be fix or should I just take to the dealer.
Thanks yall
Old Feb 25, 2011 | 08:47 PM
deception0311's Avatar
2004 Mercedes CLK500 (W209)
You shouldn't have to take of the center console, the CD changer is held in place by 2 brackets in the glove compartment. The dealership is going to probably going to charge you double to get it fix, I would just find a local audio repair shop and let them take a look at it.
Old Feb 25, 2011 | 09:14 PM
forhim's Avatar
2003 clk500
Thanks D ~ I took it to a audio repair shop and he tried to take it out. But said he couldn't get to the left side unless he took out the console. He said if I had some instructions he could do it. He could not find what the other bracket was attached to. Any suggestions.
Old Feb 25, 2011 | 09:24 PM
I actually took my cd changer out and install an after market double din head unit.
This will show you had to take the center console out.
Check out this link: http://w209forums.com/showthread.php...-Console-Cover
Old Feb 25, 2011 | 09:36 PM
forhim's Avatar
2003 clk500
Did you have to remove it from the console (I'm guessing not)...Because I did ask about a head unit and was told I couldn't. Should I look elsewhere???
Old Feb 25, 2011 | 09:45 PM
Actually I really didn't have to remove the center console, There's 2 brackets holding the CD changer down in the glove compartment and it came out pretty easy. I notice that when you take out the center console trim you can see that the wire run from the head unit to the CD changer so you should try to take it out and see if you can access it.
Let me know what happens!
Old Feb 25, 2011 | 09:58 PM
forhim's Avatar
2003 clk500
Thanks I will....
