Cam Questions
http://www.youtube.com/watch?v=shgw1AANOF0
http://www.youtube.com/watch?v=24XIqtajQbM
Hope this helps your decision
Cheers _PTEngineering
). - I'm concerned with passing the Smog sniffer test with these cams, can you confirm whether that would be an issue?
- I assume these cams are for N/A M113 V8s (you have a 2005 CLK55 right)?
- Did you do any hardware changes to the transmission in order shift so fast (for a Mercedes CLK
)? - Is there a webpage I can go to get more info on the cams/TCU?
this is my cars shift =D
http://www.youtube.com/watch?v=hscbUsBgYE0
With the Supercharger installed, I've noticed that the transmission shifts are REALLY slow (no slower than before, but now it's noticeable); so when I saw this video I had to find out what was done.
Everything is good man. Glad to hear the beast is running smooth. I'm also waiting on some more info about these cams. I will hopefully be starting my build at the end of the month and really don't want to spend $2500 on Kleeman cams.
Did you ever post a video?
Next time I go WOT, I will take note of the shift RPM.
I want to clarify my earlier comment. My transmission does not behave any differently than it did before my Supercharger install (if anything, the tranny short shifts more under normal driving because of the extra torque). The perception of speed is greater (because of the extra torque and better top end), so when it's finally time to shift, the lag is even more noticeable (verses the stock motor). When I saw PTE's transmission shift, I could tell right away that the shift times improved and so I wanted to inquire what TCU/Tranny mods he did.
The reason I asked is because my CL55 w'HPS Supercharger were having slow shiftting problem at top and cause the engine to hit the redline rev limiter. It reality, it was not because of tranny shifting slower (it was still shifting at the same speed) it was because the power came out way faster now with the sc and the engine hit the rev limiter before the tranny shift. To fixed the problem, we rise the engine rev limiter to 6600 rpm to give time for the tranny to shift and fixed the problem.
As for PTE, he has been replying in the CLK55 AMG section.
500/550-K2: K1 + a set of stainless steel tubular exhaust headers and downpipes + sport cats for some models. Up to 435 HP and 600 Nm (724 lb-ft) of torque
500/550-K2: K1 + K2 + a set of super sport camshafts. Up to 460 HP and 630 Nm (450 lb-ft) of torque.
im touching myself to those numbers!
BTW, did you ever get that 550 on a dyno???
