CLK will not start!! HELP!
Old Apr 8, 2011 | 01:24 PM
chrislis's Avatar
2005 CLK500
Originally Posted by mig1980
So I pulled the codes on the car and it gave me a code for the Crankshaft position sensor. I order it for about $50 and will be installing it next week.
Old Apr 8, 2011 | 05:00 PM
mig1980's Avatar
2003 SL55, 2006 CLK500, 1998 Vette
So I found a link as to how to install the sensor but it has a diagram from the WIS ASRA softwrae. It asks to remove the air filter housing, remove the hot film mass air flow sensor, and finally remove the air duct housing.
Could someone that has the software pull information for me as to how to do these three parts? The section numbers appear as follow: AR09.10-P-1150QB, AR07.07-P-1453QB, and AR09.20-P-0080QB
I would really appreciate it.
Thank you
Old Apr 8, 2011 | 06:00 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Originally Posted by chrislis
Geez dude, the guy just wanted to make sure. And he did.
Old Apr 10, 2011 | 10:00 PM
mig1980's Avatar
Could anyone help me on this please...
Old Apr 10, 2011 | 10:04 PM
Mka77's Avatar
Maybe klinh will chime in tomorrow morning with some direction on the r and r.
Old Apr 13, 2011 | 03:05 PM
mig1980's Avatar
Can anyone tell me if and why I need to remove the hot film mass air flow sensor? If so, how do I do that? I would really appreciate some further help as I am looking to tackle this task tonight.
Old Apr 14, 2011 | 01:29 AM
  #32
mig1980's Avatar
So I tried fixing this issue myself tonight and couldn't fix it. I managed to remove the mass air sensor but just couldn't find or reach the CPS to remove it and install the new one.
In the process I broke the collar that wraps around the maf. Does anyone know if I can buy just the collar or does that come with the maf? What is this part called because I haven't been able to find it online?
If anyone can still help me remove the CPS that would be greatly appreciated.
Old Apr 14, 2011 | 01:56 AM
  #33
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
So I tried fixing this issue myself tonight and couldn't fix it. .
Why removed the MAS? Sound to me you don't know where the CPS located? These link may help you.................
http://www.peachparts.com/Wikka/M112M113CPS
Old Apr 14, 2011 | 02:37 PM
  #34
mig1980's Avatar
This information is for an S or ML class. is it in the same place for the clk?
Old Apr 14, 2011 | 04:44 PM
  #35
Supafly's Avatar
I drive the racism out of BadDebt. ;)
heres my 2 cents as I have done this job for countless people here in vancity.
The most easy and quickest way to replace the CPS sensor is to
remove airbox
purge fuel line (to allow for valve cover removal)
remove right valve cover ( to allow for more hand movement and flexibility)
then remove cps sensor...
Old Apr 22, 2011 | 11:05 AM
  #36
slowCLK's Avatar
clk
my CPS went out **** me !
Old May 27, 2011 | 12:48 AM
  #37
eman88's Avatar
CLK-550
My 2004 CLK500 was hard to start this afternoon and it just threw a check engine light, I'll be going to autozone in the morning to pull the codes....maybe my CPS is going as well
