quixx remover works on deep scratches!
so i put touch up paint (obsidian black) on the deep fingernail scratch. once it was dry, i then used the tube 1 and polished it with a lot of pressure for about a 1 min. i had to add the tube 1 polish about three times or so in order to completely remove the paint outside of the scratch. you can tell it is removing as the white towel is now black. once i was satisfied with teh excess paint removed, i then used polish 2 to buff it out. and now, i can barely notice the scratch!
i rate the scratch removing, 9.5/10 and no other product i have used has come out with these kinda results. the lankra remover i used before did not fill the scratch and meguiars scratch x only removes fine scratches, not deep ones...
who knows. I have a coupe i need to fix so will give it a try.http://www.amazon.com/Quixx-00070-US.../dp/B000UVUAFO
