removing buffer trails
and scratch x will be much too abrasive... check the detailing section of the board for what to use.
Talk to Ken. He can help you out. He will show you everything and teach you at the sametime. A bit of a drive into maple ridge, but well worth the trip.
Call in advance though, because he does outcalls a lot.
https://mbworld.org/forums/detailing...ear-coats.html
ok i followed this link's instruction, and did one of the rear doors on my suv. after applying more pressure and rubbing in a small section at a time only by hand and no machine, it actually removed the swirls!
tomorrow i will try this method by hand again and see if all the buffer trails/holograms will be completely removed.
what i did before was put on a light layer of meguiars scratch x and quickly wiped it away with a microfiber towel. the instructions in the link states to rub it in and work it in fairly good and i did that now and it seems to work!
more importantly, it also removed light scratches and spidery swirl marks in the process. now you can actually see the little pearl specs in the paint job...
