Loud rumbling groaning noise - ????
Old Apr 22, 2011 | 12:55 AM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
Anyone have this problem? When it's raining and the road is really wet, I get a loud rumbling groaning noise from my front left wheel. But only when it's wet. I've had this problem for about 4 years so it 's happened with different wheels and tires, it's happened when I was on 18's, it happened on my stock brakes.
Becasue it's ONLY the front left, my only guess is that something electrical is getting wet. Or the water is somehow causing some friction on the bearings. What do y'alls think?
Old Apr 22, 2011 | 01:04 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I think you got loose screws in your head.
Old Apr 22, 2011 | 08:03 AM
TechSuperstar's Avatar
15' CLS400
Sounds like a bearing to me
Old Apr 22, 2011 | 06:35 PM
lowpost's Avatar
Thanks! Any ideas on why only when wet?
Old Dec 31, 2011 | 02:15 AM
RaymanS41's Avatar
2003 CLK 500
Sorry for bringing back an old thread but I am having this same problem on a 2003 clk500.
OP - did you ever figure out what it was?
Old Dec 31, 2011 | 03:46 PM
lowpost's Avatar
not sure yet - I had the bearing replaces in Sept, but we've had almost no rain out here in Cali to see if that was the issue. My shop also noted that the bearing wasn't packed correctly with grease which was odd to me because it was still original. They probably meant it was lacking grease due to normal wear/time. Will update this.
Old Dec 31, 2011 | 07:06 PM
JDenhamCLK320's Avatar
2004 CLK 320, 07 Yukon SLT, 05 R6raven
I've notice the same issues when it rains. :-/
Old Jan 1, 2012 | 07:49 PM
RaymanS41's Avatar
2003 CLK 500
On mine, I don't think it's the bearings. If I hit a large enough puddle and get whatever it is wet enough, the noise is present when stopped and at idle. I thought my exhaust was loose the first time I heard it but ruled that out when it only happened in the rain. Now I'm suspecting the belt but there should be enough plastic under there to cover it from the rain.
I'll have to take a closer look under there the next time I do an oil change.
