***Official Wheel/tire/stance Fitment Thread***
#1026
you will have to buy new bolts, they make the head in 2 different styles also, but its not uncommon for that, it isnt the fact the one are 16 and the other are 18's. its the style and thickness of the wheel itself, also you have to be careful they arent to long and hit the brakes on the inside. So after you put the new ones on spin the wheel by hand to make sure there is nothing touching
i'll try the spare wheel bolts for fit and see how much longer i need to go, or if they're the right length.
wrt bolt style, is this the difference between tapered and radius, or is there something else i need to consider? like the thread
#1027
yes there is a difference between tapered and radius, that the shape of the head where it seats into the wheel, you have to look at the shape of the whole of the wheels to see what style you have.
Thats all you need to consider which head style and length
#1028
ok, so i measured the hole diameter on the new wheels and they're 15mm across. can i run 12mm bolts in this? do i need some sort of custom bolts with M14 seats and M12 thread?? are there washers i can use to fill the gap?
#1029
no washers just get the correct style seats, my wheels are off an e class that takes larger diameter bolts also, its not issue using the smaller bolts
#1030
#1031
Here is the best pic i was able to get of the clearance on the inside of the front wheel. I can fit my pinky between the strut and wheel
#1032
I don't think a 235 with a 9" would fit if that's the clearance you have, correct me if I'm wrong.
#1039
2005 E55 AMG
For anyone who is curious how certain offsets sit, here we go. There are many factors that play a role wether or not it fits or not: Offset, tire brand, suspension etc.
19x8.5 ET24 (225/35/19)
19x10 ET20 (255/30/19)
H&R Coil Overs. Stock Camber.
#1042
2005 E55 AMG
Exhaust tips
They're no brand, custom made. My guy had to build a y pipe and connect these tips because they were the only option at the moment that somewhat fit the dimensions between the diffuser. I still plan on ordering the AMG tips as I like the oem look.
#1043
1 Post
2003 C230 K , 2001 ML320
At the dealer today, they want to replace the front wheel hubs???? Only $2000 because they also have to replace the wheel bearings and wheel balance and alignment.
I am still looking at what factory rims will fit my 2008 CLK 350 Cab. I like the 18 inch E class multi spoke A212 401 5502 7x45 with ET of 48 comes in just the ET48. The other E class 18 inch rims use an ET of 54 for the rear.
Will these fit of do I need an ET closer to 35? I want the factory rims as they are available from dealers as take offs, and are usually forged and lighter.
#1044
1 Post
My 2006 CLK 350 Cabriolet Capri Blue is bone stock, although I will probably put the CLK 500 brakes on the front. I really want factory rims as they are forged and usually lighter than after market. I always go with W rated tires as it gets hot here in Lost Wages. Not much into super power now that I have 7 grandkids.
What ET for I need for the front and rear not using spacers, with 18 inch and 19 inch rims?
Thank you
Thank you
#1045
1 Post
Can someone identify the wheels shown on post 781
by GunMoto.
He identifies the ETs, the bolt size and length, great post.
I think they would look good on my stock cabriolet
oem w219 wheels
#1046
1 Post
OK there are a lot of CLS wheels out there (2006-2011) with ETs of 25/28 and 28/33.
Seems the 2012 and later have larger ETs.
So many have tires with the wheels, 8.5" ET 28 tire 245/40/18 and rears are 9.5" ET 33 tire 275/35/18
So will these fit on my stock 2006 CLK 250 and can they fit with spacers.
#1047
W209(sold), W212, X204
CLK55 Wheel Fitment - YouTube
#1048
KB - you plan on getting rid of the forgestars? I'm still running mines with different bolts, all is fine but i just don't feel safe after what happen smh
#1049
#1050
1 Post
Got my CLS rims today, black powder coated. ET 30 front @ 8.5 inches, ET 33 @ 9.5 inches rear.
My 2006 CLK lugs are 1.55 inches past the ball, or 39mm. Put into the CLS rims there is too much length past the rim, 1 5/16" or 33.3 MM.
I have some other lugs left over 7/8th inch past the ball, leaving 3/4 inches past the rims.
Otis Inc. has lug bolts 25, 26, 28, 30, 32, 35 mm shanks. What length would you recommend?
I was thinking 25 or 26 mm would leave about an inch behind the wheel.
