***Official Wheel/tire/stance Fitment Thread***
Old Apr 21, 2016 | 04:59 PM
  #1051
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
install one of the longer ones you have, and measure how much is sticking through when its mounted and do the subtraction
Old Apr 26, 2016 | 10:23 PM
  #1052
Tito Torres's Avatar
2006 Benz c280 4matic
Originally Posted by Jamesbbh
B. Post wheel: Linea Corse LeMans I painted Satin Black-19x8.5 F-19x9.5 R-Can't remember the offset right now.
C. Tire: BFG KDW II's- 265/30ZR19R-225/35ZR19F
D. If using spacers: 10 MM spacers on all corners-generic-shortened lug bolts
E. If lowered: Eibach springs 1.2" all around- No camber kit
F. Any issues with your setup or warnings about previous setups- nope
What size in length are the shanks on your lug bolts and how much of you lug bolts bolted on your rotors?
Old Apr 29, 2016 | 11:01 AM
  #1053
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
why don't you guys just convert to studs and be done with guessing sizes on lug bolts? it offers a really nice convenience when changing wheels often.
http://www.apexraceparts.com/apex-pr...l#.VyN2-kY5X1Y
Old Apr 30, 2016 | 09:03 PM
  #1054
breastroker's Avatar
2003 C230 K , 2001 ML320
w209 clk350 Cabriolet (stock height) on oem w219 wheels. No body wanted these wheels, on eBay for over 6 months. I got the black powder coated CLS wheels for $550 shipped. The CLK lugs are at least 39 mm past the ball seat.
- 18x8.5 et30 | 225/40-18 Pirelli P Zero front wheels
- 18x9.5 et33 | 255/35-18 Pirelli P Zero rear wheels
- 12x1.5mm lugbolts | R14 ballseat | 25 mm shank
B. Post wheel: W219 CLS Black-18x8.5 ET 30 Front-18x9.5 ET 33 Rear
C. Tire: Pirelli P Zero - 225/40ZR18-255/35ZR18
D. If using spacers: No spacers
E. If lowered: Pure stock for now
F. Any issues with your setup or warnings about previous setups- none
***Official Wheel/tire/stance Fitment Thread***-2006clkblackwheels1_zpsif48tdfk.jpg
***Official Wheel/tire/stance Fitment Thread***-wheelfitment_zpsftofgd0y.jpg
***Official Wheel/tire/stance Fitment Thread***-cls4_zpsexpwv871.jpg
Old May 28, 2016 | 12:35 AM
  #1055
DiceCedes's Avatar
21 AMG GT Stealth Edition
Lugbolt specs
So I am looking at the CLS 19 OEM AMGs for a full size spares I know the offsets will work but do you know if the stock lugbolts will work or do you have to change them?
Old Jun 7, 2016 | 11:00 PM
  #1056
vinsuz's Avatar
2007 CLK 550
Question In need of advice and guidance
Hi Forum,
I am finally looking to replace my oem 17" five spoke AMG wheels and am looking at 19" Mandrus Mannheim's, 8.5 @ 32 offset and 9.5 @ 35 offset. I do have the sport suspension (factory lowered, coil overs, bigger front calipers?), so my first question is do I have the clearance?
Secondly, what tires sizes are recommended? A couple of online retailers are showing 225/35 in the front and 255/30 in the rear, but I've had a sales rep suggest 235/35 in front and 255/35 in the rear. But having the same sidewall ratio on a wider tire will give me a taller tire in the rear -- this guy can't know what he's talking about, right? So my real question is whether I should go 225 or 235 in the front (assuming 255 in the rear). Or should I even go 265 in the rear?
As you can see, I need help! Thanks in advance for your input.
Vin
Old Jun 8, 2016 | 12:47 AM
  #1057
jkiddd33's Avatar
2005 E55 AMG
Fitment
What year is your clk55 and what suspension?
If you have bigger breaks 32 with coilovers won't come close to fitting.
Originally Posted by vinsuz
Hi Forum,
Vin
Old Jun 8, 2016 | 07:17 AM
  #1058
vinsuz's Avatar
2007 CLK 550
I have an '07 550, but I can't remember if the sport suspension package (aka AMG appearance package) included larger front brakes. They are cross-drilled, so I'm pretty sure they are an upgrade from a base model.
Old Jun 8, 2016 | 07:17 PM
  #1059
jkiddd33's Avatar
2005 E55 AMG
Look at my threads. I have a fitment post.
There are alot of posts touching on your exact questions.
Ps 235 35/255 30 is fine. I would do 265 since 35 ET is not aggressive.
https://mbworld.org/forums/clk-class...ml#post6742830
Old Jun 8, 2016 | 10:16 PM
  #1060
vinsuz's Avatar
2007 CLK 550
There are 43 pages in this thread. I searched for posts regarding the factory sport suspension but resorted to posting my own question. Again, these are factory coil overs, not aftermarket, so if a 32 offset won't fit, what will. I prefer to not use spacers if I can avoid them.
Old Jun 8, 2016 | 10:39 PM
  #1061
gixxerboy's Avatar
because is never heard of a clk550 coming with coil overs from the factory. The sport suspension and amg package you are referring to does not come with coil overs
Old Jun 8, 2016 | 10:48 PM
  #1062
jkiddd33's Avatar
2005 E55 AMG
Coils
+1gixxerboy.
Old Jun 8, 2016 | 11:07 PM
  #1063
vinsuz's Avatar
2007 CLK 550
Okay, I just found a post from Rodney on Benzworld which says the sports suspension has sport-tuned shocks and struts, with no mention of coil overs. That said, so a 32 offset would work, right?
And to confirm jkiddd, you are suggesting 235/35 and 265/30 on the 19's, right?
Thanks for your feedback!
Old Jun 9, 2016 | 02:04 AM
  #1064
jkiddd33's Avatar
2005 E55 AMG
I am not 100% sure but since its not coil overs, 32 should be ok. If coils at least 25 ET upfront on a 8.5.
Also yes run 235/35 and 265/30.
Old Jun 9, 2016 | 12:52 PM
  #1065
eweezy510's Avatar
1999 cl500 w140 coupe
hello! i am in a dilemma, im in need of one lorinser rsk 5 center cap, i was wondering if anyone knew if the d93 cap will fit? obviously different as far in style but looks seem maybe it can spin right on? i haves earched the forums looking for a centercap thread to post on that can maybe better help me with results but cannot find any. thank you!
Old Jun 28, 2016 | 11:00 PM
  #1066
vinsuz's Avatar
2007 CLK 550
Thanks for all the advice guys. Just installed my new wheels and tires and got a fresh alignment to boot.
Excuse my ignorance, but aren't these coil-overs?
Old Jun 28, 2016 | 11:01 PM
  #1067
vinsuz's Avatar
2007 CLK 550
Holy crap, that picture is huge!
Old Jun 29, 2016 | 01:02 AM
  #1068
jkiddd33's Avatar
2005 E55 AMG
No, they're not coil overs.
No they're not coil overs.
Old Jun 29, 2016 | 01:06 AM
  #1069
jkiddd33's Avatar
2005 E55 AMG
Coil overs
Here's mine.
H&R coil overs
Old Jun 29, 2016 | 03:02 AM
  #1070
vinsuz's Avatar
2007 CLK 550
I'm not sure I see the difference.
Old Jun 29, 2016 | 08:38 AM
  #1071
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
They are nearly the same thing. the biggest difference is adjustability.
Old Jun 29, 2016 | 12:53 PM
  #1072
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
your picture are springs. they provide one ride height.
coil overs are springs but with an adjustable "seat" that allows you to adjust the ride height. so in the coil over pic there's a red metal piece the spring sits on that can rotate on threads compressing the spring to whatever height you want.
Old Jun 30, 2016 | 06:53 PM
  #1073
vinsuz's Avatar
2007 CLK 550
Gotcha, thanks guys.
Old Aug 8, 2016 | 04:10 PM
  #1074
Ridge Lock's Avatar
Mercedes Benz CLK 500
Hello all,
I bought this CLK recently. But I don't like the wheels that much. As I would like to see what you guys think. If you had these wheels shown on the picture below, what would you do? The info is as follows.
A. Post a pic of your car - see below
B. Post wheel: Size, Width, Offset. - 225/40ZR18 front, 255/35ZR18 back
C. Tire make/size - Hankook V12 EVO
D. If using spacers-size and manufacturer. Shortened lug bolts or not.- no idea
E. If lowered- what manufacturer and how low. Also, if using a camber kit or not. - not lowered
F. Any issues with your setup or warnings about previous setups - no issues
Old Aug 25, 2016 | 04:46 PM
  #1075
Lumpking's Avatar
06 E350
Front wheel
I recently bent and cracked a front wheel. It was 19x8.5 32ET. The wheels are discontinued and I don't feel comfortable with a repaired crack in the barrel. I was able to find the same wheel in a different size. Would these fit my 550. 19x9.5 ET45. I would add a 10 mm spacer. Would these clear for the fender? Keeping the 235/35/19.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
