Service Indicator Truth
Old Jun 20, 2011 | 06:34 PM
tberns's Avatar
CLK500
I'm a newbie to the forum. Just started driving an 04 CLK 500. The B service warning has triggered based based on time (2 years); only have 4,000 miles since last service. After much research and trying every method suggested, can't clear the indicator. Dealer and local shop (who want to make big $$$ doing an oil change) tell me that no matter what Owner's Manual says, I need to have the indicator reset by the dealer or someone with a "star" computer. What is the truth??? Any help appreciated.
Old Jun 20, 2011 | 07:26 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Take it to an Independent MB shop.
Old Jun 20, 2011 | 07:44 PM
bheng's Avatar
2003 CLK 320
im surprised you werent able to reset it with the method that mbworld member klinh posted up. if you cant, take it to an indy shop as wes suggested and have them reset it. although, you should do an oil change.
Old Jun 21, 2011 | 09:47 AM
tberns's Avatar
CLK500
Thanks. I tried the suggested method, but could not get the system to display the service indicator page. I plan on searching out a good independent MB shop.
Old Jun 21, 2011 | 12:32 PM
dragon_27's Avatar
03 clk500, 06 qx56
agreed, they can do it. stealership always says things like that so you can bring it to them
Old Jun 22, 2011 | 02:27 AM
kbahl21's Avatar
CLK & GL
when the service message go into the super secret menu(the one for dynomode) in that menu it shows/asks you if u want to clear service...ive done it a few times since i get an oil change every 4kmiles and the Service they tell you that you should do is bull****. Why pay Mercedes a hundred something dollars an hour to Visually Check your brakes
Old Jun 22, 2011 | 02:38 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Can you list the first 2 steps of what you did? Maybe we can help you. I know step 1 step is the most importance step.
Old Jun 24, 2011 | 01:14 AM
JHouse's Avatar
2014 CLS 550 & 2004 CL55
Mine was a butt pain, only because I was too lazy to go through the manual slowly to understand which knobs were which and such, and it is a tad ambiguous. But after about 6 tries I figured it out. It will probably be just as hard the next time too.
Old Jun 30, 2011 | 11:55 AM
dragon_27's Avatar
03 clk500, 06 qx56
yeah i'd like to know the steps to do it myself too. i just changed my battery and now it says service a is past due, but i don't need another service for another 8000 km...
edit i will search for klinh's writeup on how to do it...
Old Jul 16, 2011 | 07:28 PM
dragon_27's Avatar
03 clk500, 06 qx56
ok i did the search and tried both instructions on how to reset the service indicator and it doesn't work. i have the key-less go push button start. i did use the key, but i never got to the menu settings. what am i doing wrong?
