6/4 pot AMG brakes
Mercedes CLK 320 W209
6/4 pot AMG brakes
Hey guys,
I'm doing some research before buying the 6/4 pot AMG brake calipers(from a W211).
I need your help to fill in some blanks.
Iv'e talked to lowpost that has the 6/4 pot from a CLK AMG.
He said I might need new spindles if I go with the brakes from a E55 W211.
1. Is this correct? (Im not doubting you lowpost just need to double check)
2. Can I use my current spindles with some modification?
3. Can I use my current brake lines with the amg calipers?
4. Can I buy spindles from any W211 (E350 and such) and use them. Will they fit my car?
5. Iv'e read that 8 pot amg calipers can fit any MB car after 2000 with some modification. Is this correct? What modification needs to be done?
As you can tell this is out of my knowledge so I need 100% correct answers on my questions guys before I buy the calipers, so no "should" or "maybe" answers please. They are kinda pricey and I need to know if the modifications needed to be done costs more than the calipers themselves.
Thanks!
Thanks!
Hey guys,
YES
I don't think so........but not sure.
I don't see why not.
I believe E spindles only fit on the E-class.
Thanks!
YES
Thanks!
Thanks for the help klinh.
Iv'e found a company in Denmark that specializes in this stuff and I'm giving them a call just to be sure that everything will work.
As I have understood it I can still use my current spindles, I just need to buy some kind of adapter for my spindles and everything work.
Thanks again!
Thanks again!
I saw a C32 today, and the 4 pot calipers aren't that small as they might look on pictures.
i will argue against it as its a big improvement from the stock brake set up of the 320. and much cheaper of a mod than the 6/4. not to mention, you us 320s dont need THAT much braking power. mostly for aesthetics haha
id say go this route if you have the cash flow.
There are many unanswered questions about the 8/4 pot brake upgrade but one of my friends found this guide:
https://mbworld.org/forums/clk-class...-w208-clk.html
2018 E43 | 2017 GLS450 | 2004 CLK 500
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
What's the cost for the 6/4 Benz conversion with rotors (I can tell you exactly what it is for the Brembo GT kits)? The stock AMG 4pot calipers painted up with some R1 drilled rotors look pretty darn good Mike (a few members have done it), if you're just going for looks a new 6/4 conversion is a serious chunk of cash...
What do you think Kev, worth it?
Rmember, you're asking an old guy what his opinion is...
Thats a fraction of what I paid for my Brembo GT kits. Do I think it's worth it? Nope mate, I don't UNLESS the pads and rotors on your 320 are needing replacement - then it's a little more reasonable as you'll need to spend a good chunk of change doing the work anyways so you might as well spend a little more and upgrade. Another thing when it comes to cosmetics, you'll appreciate it more than 99.99% of the people out there that see the car will so in the end - do what makes you happy pal.
Rmember, you're asking an old guy what his opinion is...![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
And you're not an old guy, you have the most youthful looking car of us all
