Nav retrofit on 2005+ facelift CLK500?
2005 CLK500 cab, 2004 S600 designo mocha
I've done some searching and found many CLK nav retrofits. The only problem is that they are mostly for European upgrades, w208 to Command 2.0 retrofit.
I have a 2005 CLK500 with factory CD player/changer. I have a 2005 CLK Nav unit I would like to install. I assume all I need is the harness and GPS antenna? Then take the vehicle into MB to program the unit for my car?
Can anyone confirm the part numbers for the harness and antenna?
the harness you have now on your cd player should work, just unplug and plug your nav in, just need a GPS antenna (i got one from eBay for $24). no need to reprogram anything......goodluck
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
beg to differ
on the re-coding....
stealership charged me 1 labor hour for the 5 minute job
find an indy with the right coding device
'07 GL450, '13 SL550
NAV backwards?
I just installed an MCS-II Comand from an 07 w209 into my 05 w209. The nav position is correct when I power the union but when I drive the direction of travel is reversed. So no matter what direction I drive, the gps goes the opposite direction.
Anyone have any idea how to fix this?
MBworld Guru
So literally it is showing your car in the wrong place on the map, and the more you drive, it continues to show you further from your actual location? Or, are you saying the map us upside-down so it drives toward the bottom instead of top?
Crazy, huh? Any ideas?
