*HELP* Fog Light Issues
Old Sep 14, 2011 | 06:51 PM
superstarks01's Avatar
Mercedes CLK 500 (Sport Package) 97 Mitsubishi Diamante
Hey guys, Ive had my 04 CLK 500 for about 3 months now and im just getting around to doin custom work on it which has led me to my fog light issue. When I bought the car I noticed the fog lights were missing and I was aware that the previous owner had hit a deer and done some slight damage to the front bumper which was replaced. Well for some reason the numb-nuts didnt replace the lamps, nothing is there but the mesh... I cant find the wires nor a Diagram showing where they would terminate. Can anyone help me with a picture or a diagram that would show me where they may have cut them, "it if this is what they did", so that I can replace them. Trying my best to keep away from the stealership. Getting tired of the left/right fog lamp error.
Thanks...
Old Sep 15, 2011 | 01:52 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
If you don't already have a new set of fogs to put in there, eBay has them regularly. Also, there must be a bulb connector tucked up in behind there somewhere, it would be very strange if they cut it off and tucked the wires into the loom
Good luck.
***Edit*** Hopefully someone can get the info you need but if not, I will get you the wire colors and a pic as I am going to be changing out my fogs fairly soon.
Old Sep 15, 2011 | 06:14 PM
OcangCLK's Avatar
W209 - 2004 CLK 320
I have a set for sale if you're still looking to purchase used ones. $130 shipped to your door.
Old Sep 15, 2011 | 07:48 PM
Good luck.
AWESOME!!! You are the man! I was beginning to worry... Thx paciently waiting...
Old Sep 15, 2011 | 07:52 PM
Thx but im planning on going with the 9 LED bar and fabbing a custom housing to hold them.....I have a cool idea with colored plastic slides that i want to use to change the color on the fly by sliding them in front..... BUT... if It tanks or I get frustrated and scrap it Ill pm you if you still have them....
thx
Old Sep 16, 2011 | 12:08 PM
advans's Avatar
C55 ///AMG, 535xi
thx
they sell this LED bar on superbrightleds.com
maybe you should start from checking the wires from the LCM to the fuse box, and go from there I'm sure your fog wires are SOMEWHERE, just hidden.
you might have to cut the existing fog brackets to put the LED bar. you can probably fab a mounting clip and U shape to mount to the bumper bracket. tough, but I've been thinking about doing something like that.
But now, how would you solve the mesh issue.
Old Sep 16, 2011 | 06:41 PM
Well Im gonna attach the light bar directly to the mesh in the middle with some sort of stiff anchor point to keep them from shaking while driving. Ill probably find some oem lamp housings and modify them to fit as I dont feel like trying to match 2 up fiberglass housings from scratch. I think the mesh will add to the look, sorta make it look line the fogs are floating.... Thats all the easy part the hard part is finding the friggin wires!.. Im usually good at tracking and finding these things but the darn engine is so massive in these cars I just can get around under there so I have to know exactly where to go to either find or splice in new ones...
Old Sep 16, 2011 | 10:27 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here's what I did on mine:
LED Fog Light Project
Old Sep 17, 2011 | 10:00 PM
That's nice Rodney!, Youre in Birmingham too aren't you? You should join my group... I'm trying to start a MB car club here and hopefully get some sponsorship an or good deals for us all...
Old Sep 18, 2011 | 07:54 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That's funny, I was driving though Helena today and saw where they had an English Car Club show this weekend and I though to myself that I should look into the existence of a local MBZ club! Yes, I'd definitely be interested - PM me!
Old Mar 4, 2012 | 01:02 PM
spence52's Avatar
2003 Mercedes CLK500
Fog light wiring issue for a 2003 CLK500
I have the same thing. I have a 2003 clk500 and the previous owner hit something that tore the driver-side wiring from the fog light and I cant find any trace of the wire. Does anyone have any info that could help me find the wire(s) or to re-wire the fog light from the point of origin. I've tried to trace the passenger fog light wires back (brown and green wires) but they (or I seem) to get them lost. Tired of the driver-side fog light warning always being on
Please help
Old Mar 4, 2012 | 01:13 PM
Kevwood's Avatar
Please help
Replied to your PM
Old Mar 4, 2012 | 01:32 PM
midnight AMG's Avatar
CLK 550
*** fosgate 12" sub = get the T1 series + 500 watt mono block amp by fosgate
fosgate hits harder than JL
Old Mar 11, 2012 | 11:51 AM
Kevwood's Avatar
Please help
I finally got around to getting to the shop and getting some pictures for you. First you can see the fog bulb connector and the wires (colors);
The wires from there go up past the washer reservoir and wheel well liner;
Then, they pass behind the headlight housing and up along the fender;
That should be enough to help you find the wires now, good luck.
Old Mar 11, 2012 | 12:22 PM
spence52's Avatar
Follow up-
Do you know or have a pic of where they connect into the fuse box? One of the issues I'm having is that I've tapped the wiring harnesses that lead to/from that direction and I can't find in brown and green wires. Other the remnants/tape that should have rapped the wires near where it attaches to the fog light
Old Mar 12, 2012 | 04:39 AM
Kevwood's Avatar
Nope, no idea. But now that you know the routing of the wires you can identify them and follow them further.
Old Mar 15, 2012 | 10:15 PM
Question
For some odd reason I was looking for the like button...... You are the man!! I'll go out tomorrow and see if I can track them down..... Thx again!
Old Mar 16, 2012 | 03:39 AM
Kevwood's Avatar
You're welcome, good luck
Old Aug 4, 2017 | 04:53 PM
Vic Rumph's Avatar
c240
Hi im new here fog lights done work where is the fuse..
Old Aug 4, 2017 | 05:15 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
there is no fuse. They are controlled electronically by the from SAM. Do you get error on the instrument cluster when you switch them on?
