"C" and "S" driving options.... I'm a noobie :)
-JD
S shifting to the lowest gear moves it down to 1.
i dont think it really makes a difference between the two other than starting up acceleration. and i believe its better in the snow because starting in second gear gets your car going slower than starting in first. im guessing less wheel spin thus safer.
Have fun. . .
The owners manual suggests that you only change from C to S at a stop, but I switch mine while driving all the time.
Doesn't make any sense to me, even though it might say that in the manual.
It might be different for a 5spd car....
It shouldn't matter what tranny you have.
Mercedes also recommends filling the car with mobile1 oil, but will the engine blow if you fill it with Castrol with same spec or with no name oil that meets the requirements?
I'm not saying I'm right and you're wrong and vice versa
"Never change the program mode when the gear selector lever is out of park position P. This could result in a change of driving characteristics for which you may not be prepared."
what's really the diff ? Is it bad to switch between the two while driving, bad on the tranny ??
