Error Codes P203a P201c
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jan 12, 2012 | 01:59 PM
chriskl's Avatar
2006 Mercedes clk 200 k sport coupe
HI Everyone
I am new to this Forum and have recently baught my first Mercedes
I have only done 2000 km it it so far and allready the derded engine light has come on
I took it to my local mecanac as the nearest stealership is over 60k away and he found the following two error codes and I would really apreceate if someone can help the codes are P203A and P201c
The Car in question is a clk 200 k sport coupe dec 2006.
any help would be greatly appreceated
Thanks,
Chris.
Old Jan 12, 2012 | 02:49 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Welcome to the group. Looks like injector issues in #1 and #3 cylinders. How many miles/KM are on the car?
http://www.permoveo.ltd.uk/tabid/122...z/Default.aspx
Old Jan 12, 2012 | 05:40 PM
Glyn M Ruck's Avatar
Super Moderator
P0201 Injector Circuit/Open - Cylinder 1
P0202 Injector Circuit/Open - Cylinder 2
P0203 Injector Circuit/Open - Cylinder 3
P0204 Injector Circuit/Open - Cylinder 4
P0205 Injector Circuit/Open - Cylinder 5
P0206 Injector Circuit/Open - Cylinder 6
P0207 Injector Circuit/Open - Cylinder 7
P0208 Injector Circuit/Open - Cylinder 8
Old Jan 12, 2012 | 08:48 PM
chriskl's Avatar
Thanks Mike,
The car has 62,000 Miles and was recently serviced its the 1.8 version.
Bought the car at a dealership in Scotland it has been regularly serviced.
Is this a common probelem and is it costly to repair ?
Thanks,
Chris.
Old Jan 12, 2012 | 11:43 PM
Mka77's Avatar
Don't know how common it is, but injectors can run anywhere from 40-100.00 each. If you are a DYI person you may be able to get it done.. Good luck.
Old Jan 13, 2012 | 07:46 AM
Super Moderator
Originally Posted by chriskl
Thanks Mike,
Thanks,
Chris.
No it is not a common failure. Modern injectors have huge life. The only common injector failures were on early diesel Blue Efficiency models with rubbish Delphi injectors.
Lucky for you you only have 4.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
