Location of Sub in convertible?
If yes, can an aftermarket sub be put there?
If I replace my stereo with an aftermarket one, I'd prefer not to use valuable trunk space for the replacement subwoofer...
200 A 203 820 01 02 LOUDSPEAKER
LEFT DOOR TRIANGULAR MIRROR 001
200 A 203 820 50 02 LOUDSPEAKER
LEFT DOOR TRIANGULAR MIRROR [023], [024]
Code: 810
001
RIGHT DOOR TRIANGULAR MIRROR 001
RIGHT DOOR TRIANGULAR MIRROR [023], [024]
Code: 810
001
210 A 203 820 11 02 LOUDSPEAKER
LEFT FRONT DOOR,BOTTOM 001
EIGHT FRONT DOOR,BOTTOM 001
210 A 203 820 51 02 LOUDSPEAKER
LEFT FRONT DOOR,BOTTOM [023], [024]
Code: 810
001
EIGHT FRONT DOOR,BOTTOM [023], [024]
Code: 810
001
220 A 000 988 66 25 TREENAIL
LEFT LOUDSPEAKER MOUNTING 003
RIGHT LOUDSPEAKER MOUNTING 003
230 A 002 984 42 29 SCREW
5.1 X 25 MM;5X25 003
240 A 203 820 40 02 LOUDSPEAKER
DOOR FRONT, LOWER REAR 002
240 A 203 820 58 02 LOUDSPEAKER
DOOR FRONT, LOWER REAR [023], [024]
Code: 810
002
250 A 000 988 66 25 TREENAIL
FASTENING SPEAKER LEFT 003
260 A 002 984 42 29 SCREW
280 A 203 820 66 02 LOUDSPEAKER [023], [024]
Code: 359
001
280 A 203 820 43 02 LOUDSPEAKER
CENTER FILL
Replaced_By: A 203 820 72 02
+001 A 203 830 45 54 [023], [024], [134], [135]
Code: 810
001
280 A 203 820 72 02 LOUDSPEAKER
CENTER FILL [136], [137]
Code: 810
001
280 A 203 820 44 02 LOUDSPEAKER
CENTER FILL
Replaced_By: A 203 820 73 02
+001 A 203 830 44 54 [023], [024], [134], [135]
Code: 273+810/359+810
001
280 A 203 820 73 02 LOUDSPEAKER
CENTER FILL [008], [139]
001
315 A 203 820 39 02 .LOUDSPEAKER
BASS BOX Code: 810
001
310 A 209 820 23 02 LOUDSPEAKER
SUBWOOFER [023], [024], [909]
Code: 810
001
930 A 003 545 18 26 CONTACT SPRING
1.5-2.5 MM2 JPT
Replaced_By: A 004 545 53 26 NB
930 A 004 545 53 26 CONTACT SPRING
1.5-2.5 MM2 JPT NB
953 A 011 545 81 26 CONTACT SPRING
0.5-1.0 MM2 JPT NB
310 A 209 820 24 02 LOUDSPEAKER
SUBWOOFER [023], [024], [910]
Code: 810+X00/810+X50
001
285 A 000 994 96 45 CLIP
MOUNTING, LOUDSPEAKER Code: 273/359/810
002
953 A 004 545 53 26 CONTACT SPRING
1.5-2.5 MM2 JPT NB
430 A 030 545 28 28 SOCKET HOUSING
CENTERFILL SPEAKER
2 PIN;H2/27 Code: 810
001
444 A 210 545 63 28 PIN BUSHING HOUSING
LEFT FRONT LOUDSPEAKER
2 PIN;H4/1 001
RIGHT FRONT LOUDSPEAKER
2 PIN;H4/2 001
BASS-BOX SPEAKER
2 PIN;H4/17 001
490 A 030 545 28 28 SOCKET HOUSING
2 PIN;H4/1 001
2 PIN;H4/2 001
925 A 210 545 63 28 PIN BUSHING HOUSING
SUBWOOFER
2 PIN;H4/29 001
899 A 000 540 46 05 REP.SET CONTACT
0.75 MM2 MQS [030]
NB
10 A 209 820 53 89 OPERATING UNIT
RADIO AUDIO 50 APS
Replaced_By: A 209 820 67 89 [525]
Code: 525
001
10 A 209 870 09 89 OPERATING UNIT
AUDIO 20 ECE
Replaced_By: A 209 820 65 89 [012], [096], [097], [525]
Code: 523
001
10 A 209 820 65 89 OPERATING UNIT
AUDIO 20 ECE [525]
Code: 523
001
10 A 209 820 67 89 OPERATING UNIT
RADIO AUDIO 50 APS
Replaced_By: A 209 870 19 89 [012], [102], [103], [525]
Code: 525
001
10 A 209 870 19 89 OPERATING UNIT
RADIO AUDIO 50 APS
HU
Replaced_By: A 209 870 22 89 [012], [104], [105], [525]
Code: 525
001
10 A 209 870 22 89 OPERATING UNIT
RADIO AUDIO 50 APS [697]
Code: 525
001
10 A 209 870 10 89 OPERATING UNIT
Replaced_By: A 209 820 66 89 [012], [096], [097], [525]
Code: 535
001
10 A 209 820 66 89 OPERATING UNIT
AUDIO 20 CD USA
Replaced_By: A 209 870 21 89 [012], [106], [107]
Code: 535
001
10 A 209 870 23 89 OPERATING UNIT
RADIO AUDIO 50 APS [525], [697]
Code: 525
001
15 A 211 827 28 62 .COMPACT DISC PLAYER [108]
Code: 525
001
15 A 211 827 29 62 .COMPACT DISC PLAYER [108]
Code: 525
001
10 A 209 870 21 89 OPERATING UNIT
AUDIO 20 USA Code: 535
001
20 N 000000 0003242 SCREW
RADIO ATTACHMENT
5X20 Code: 752/754/756/254
002
RADIO ATTACHMENT
5X20 004
30 A 169 584 65 82 OPERATING
GERMAN
COMAND ECE Code: 202+526+807/202+527+807/202B+526+807/202B+527+807
001
30 A 169 584 66 82 OPERATING
ENGLISH
COMAND ECE Code: 205+526+807/205+527+807/205B+526+807/205B+527+807
001
30 A 209 584 11 96 OPERATING
GERMAN
AUDIO 20CD [047], [007]
Code: 202+523/202B+523
001
30 A 209 584 12 96 OPERATING
ENGLISH
Code: 203B+523/205+523/205B+523
001
30 A 209 584 25 96 OPERATING
GERMAN
AUDIO 50APS [047], [007]
Code: 202+525/202B+525
001
30 A 209 584 02 96 OPERATING
ENGLISH / RUSSIAN
Code: 203B+525/205+525/205B+525
001
50 A 169 820 80 89 AMPLIFIER
SOUND AMPLIFIER [672]
Code: 810
001
80 A 004 994 16 45 SPRING NUT
FASTENING AMPLIFIER
M6 [121], [122]
Code: 810
004
80 A 003 994 17 45 CLIP NUT
FASTENING AMPLIFIER [123], [124]
Code: 810
004
70 A 140 990 00 04 SCREW
SOUND AMPLIFIER [023], [024]
Code: 810
004
150 A 203 870 33 89 CD CHANGER
IN GLOVE COMPARTMENT [047], [007], [525], [672], [697]
Code: 819
001
155 A 002 820 62 89 .CD HOLDER Code: 819
001
160 A 209 827 09 14 HOLDER
CD CHANGER Code: 819
001 L
160 A 209 827 10 14 HOLDER
001 R
180 A 001 984 89 29 SCREW
AT BRACKET
5X16 Code: 819
001
325 A 211 870 63 89 AMPLIFIER
AUDIO GATEWAY
AGW
Replaced_By: A 211 870 70 89 [012], [125], [126], [672]
Code: 529
001
190 N 000000 0001955 SCREW
CD CHANGER ATTACHMENT
M4X6 Code: 819
004
350 A 169 827 01 62 RECEIVER
SATELLITE RADIO [127], [128]
Code: 536
001
350 A 211 870 33 89 RECEIVER
SATELLITE RADIO [129], [130]
Code: 536+808
001
SATELLITE RADIO [131], [132]
Code: 536
001
440 A 037 545 63 28 PIN BUSHING HOUSING
SATELLITE RADIO USA CONTROL UNIT
3 PIN;N87/5 001
325 A 211 870 70 89 AMPLIFIER
AUDIO GATEWAY [672]
Code: 529
001
476 A 029 545 55 28 PIN BUSHING HOUSING
CD CHANGER
3 PIN;N87/2 003
500 A 030 545 28 28 SOCKET HOUSING
SEPARATION POINT APS 1. DIN
2 PIN;X120 001
442 A 002 545 84 40 PLUG HOUSING
4-PIN;N87/5 001
880 A 220 545 39 28 PLUG HOUSING
AUDIO GATEWAY
4 PIN;N93/1 001
523 A 030 545 34 28 PIN BUSHING HOUSING
POWER SUPPLY RADIO/COMAND
8-PIN;A2 002
524 A 030 545 35 28 PIN BUSHING HOUSING
RADIO SPACE B
8-PIN;A2 001
677 A 202 545 37 28 PIN BUSHING HOUSING
RADIO CHAMBER C,
10-PIN;A2 001
885 A 220 545 37 28 PIN BUSHING HOUSING
AUDIO GATEWAY CONTROL MODULE
14-PIN;N93/1 001
890 A 002 545 84 40 PLUG HOUSING
AUDIO GATEWAY
4-PIN;N93/1 001
894 A 015 545 65 26 PLUG SOCKET
CONTROL UNIT, SOUND AMPLIFIER
N40/3 001
896 A 000 545 84 30 HOUSING
6-PIN;N40/3 001
896 A 002 545 84 40 PLUG HOUSING
4-PIN;TO A 000 545 84 30 001
0.75 MM2 MQS [030]
NB
899 A 000 540 45 05 REP.SET CONTACT
0.5 MM2 MQS NB
900 A 028 545 54 28 FLAT PLUG
HF RELAY
9,5 - 4,0-6,0MM2;N96 001
910 A 013 545 15 26 CONTACT SPRING
0.75-1.0 MM2 SLK NB
920 A 013 545 16 26 CONTACT SPRING
1.5-2.5 MM2 SLK NB
0.5-1.0 MM2 JPT NB
1.5-2.5 MM2 JPT NB
960 A 013 545 76 26 CONTACT BUSHING
0.5-1.0 MM2 MCP NB
960 A 013 545 78 26 CONTACT BUSHING
1.5-2.5 MM2 MCP NB
take out the floor mat, pull the carpet down from the fire wall.
this should expose a black piece of foam board, pull it out
you then should see a metal plate that covers a larger than expected opening
a shop in atlanta showed me this then built a custom sub enclosure to fit down there. they did away with the faom and metal plate. the sub grill served as the support for the carpet and mat. PM me your email address and i can send you a few pictures of the install
