Slight whine
Ive been doing a lot of motorway miles in the last week and i have noticed a slight whine that increases with speed, I cant really hear anything until about 55mph and its drowned out at about 75mph.Im sure its coming from the rear end of the car and was hoping for some advice.I was thinking of changng out the diff oil as the car has loads of history but nothing saying the diff fluid has been changed.Any advice greatly appreciated.
These cars when fitted with the M112/722.6 combination like yours do hit a harmonic at approx 55 mph, 90Km/h where you hear some sympathetic whine with the diff. Once you drive through that speed it shuts up. The M272/722.9 combination does not do this. It happens on W203 & W211 as well with the M112/722.6 combo - The NVH engineering is not perfect.
The only time you should be worried is if there is a substantial difference in noise between accelerating & trailing throttle which would be a sign that the pinion bearings had lost preload.
Update time, Last night i changed my diff oil which was very much black and really stinks.The whine is still there, Im sure it only starts at around 50mph and cant hear it at 80, Dropped the car out of gear at 65 and the whine stayed as it was.Anything else i could look at? Had a gearbox go b4 on my BMW so im hoping it aint that.
Other sources of a whine could be a wheel bearing or centre propshaft bearing.
