Problem
Old Jun 22, 2012 | 07:49 PM
dazzo19's Avatar
slk350
Exclamation Problem
Hey all,
I am having some issues with my transmission. Long story short, I brought my 2006 clk500 to an authorized mercedes benz repair and they ran a diagnostics on my car. This is what came up on the report:
Code 2505: Hydraulic fault in transmittion (engaging shift element does not engage)
Code 2502: The gear is implausible or the transmission is slipping.
He advised me that an actual mercedes benz repair center located in a dealership would haveto do the repair on something like this.
Does anyone have any info on the possible cost or similar experiences?
Appreciate it
-Don
Old Jun 23, 2012 | 02:50 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'm a little confused by your terms "authorized Mercedes Benz repair (center)" and "an actual Mercedes Benz repair center located in a dealership". In the USA< there is no difference - the only service centers authorized by MBZ are dealerships.
As for the errors, I would seek assistance from a dealership. The first thing to check is fluid levels and mileage vs. last fluid/filter change (should be done at least at 39K miles initially, and really, every 39K miles). If it's not a fluid problem, then it could be a problem in the valve body and/or contact plate. Hopefully it is not a failed pump. Again, someone that knows these transmissions needs to do the work.
Old Jun 23, 2012 | 06:53 PM
Clkboi's Avatar
CLS550 4Matic
i had the same issue on my CLK 350.
Extended warranty covered all the $3000 repair.
They changed the hydraulic compartment on it!
Old Jun 24, 2012 | 06:20 AM
Glyn M Ruck's Avatar
Super Moderator
2006 was the year that contact plate & valve body problems were most prevalent.
2502 is is usually a sign of speed sensor trouble which is caused by the VDO conductor plate going bad.
Old Jun 24, 2012 | 06:46 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Rudeney & Glyn M Ruck; you guys are the Batman and Robin of the 209 forum, always swooping in and saving the day. Of course, I will leave it up to you guys to decide who is who...
Old Jun 24, 2012 | 10:50 AM
Super Moderator
Old Jun 24, 2012 | 11:37 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, we both would have to wear tights. With my physique, I'd probably look better in the Batman costume with it's pre-formed abs, as mine are a bit "lacking".
Old Jun 24, 2012 | 11:45 AM
Kevwood's Avatar
Lol. Don't worry about it, Might Mouse here
Old Jun 24, 2012 | 07:48 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
That must make you Flash or Silver Surfer, Kev....the one we like just because he's so cool.......
Old Jun 24, 2012 | 11:10 PM
Kevwood's Avatar
Much better than Mighty Mouse!
