Please check my VIN for Balance shaft issue?
#552
#555
Looking to but this 2011 E550
vin WDDHF9ABXBA374432
ID WDD2120901A374432 0
Engine NO: 273970 30 402957
I think this engine is out of the range for the issue but would like somebody that researches this to validate my findings.
Kind Regards,
Scott
Kind Regards,
Scott
#557
#558
Request for balance shaft issue check
Rodney,
There are two C280s (both 2007) that I am considering buying. Could you please check the engine numbers and let me know if there is any potential issues?
Thank you in advance. I appreciate.
VIN1: WDBRF54H27F925811
VIN2: WDBRF54H67F935029
#559
Please check my vin
Hi ya all. I am looking to buy a 350 slk. The vin number is wdb1714562f093595. It is on a 55 plate and the guy I am buying the car off of says that this balance shaft problem normally shows up at around 40k miles. This car has done 80k and drives really well. It has a full merc history other than the last 2 services which were carried out by a specialist company. It has previously had 2 owners. Any help / advice would be great.
#561
BTW
Really love the way this car drives. I had a P plated 320 estate which ran on LPG and after having owned many different cars for short periods i.e. less than a year I kept the old merc for 8 years, unlike the wife she never let me down. Now divorced I found that I no longer needed such a large utility vehicle and let her go, the 320 that is. Been merc less for around a year now and have to say it is exciting to be back behind the 3 pointed star. The car is for my new partner and the comparison between the 2 women is similar to the comparison between the 2 cars
#562
Request for checking engine for balancing shaft problem
Hi Rodney , just stumbled about this issue when I looked at a 07 C230 , but I also own a 06 SLK 350 , and am worried now , the engine has only 18500 miles on . Could you please check if this could be an effected one ? Vin is WDBWK56FX6F096236 , the engine number is
27296330169433
thank you so much , Martin
27296330169433
#563
2007 CL550 AMG/2008 ML550 AMG/1995 SL500
2007 CL550
Hey Rodney,
Can you please check this vin: WDDEJ71X17A003457
Thinking of buying this vehicle but I just want to make sure I'm safe before signing!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Thanks in advance,
AL
Thanks in advance,
AL
#564
MBworld Guru
WDBRF54H67F935029 = M272 engine #608997
Both of these are beyond the balance shaft issue range, but may still have issues with the camshaft adjuster solenoids (a.k.a. "cam magnets"). Luckily, those are cheap and easy to fix.
[/QUOTE]
#565
MBworld Guru
#566
MBworld Guru
27296330169433
27296330169433
#567
MBworld Guru
Hey Rodney,
Thanks in advance,
AL
Thanks in advance,
AL
#569
GL450 / GSX-R / Acura RL / Acura TL Type-S
Datacard
Identification number: WDB2110761A919439 6
VIN: WDBUF76J96A919439
Chassis
Sales designation: E 55 AMG
Order number: 0 6 704 13776
Delivery date: 06 12 2005
Paint code 1: 040U BLACK
Equipment: 251A LEATHER - BLACK/ANTHRACITE
Engine no.: 113990 60 051100
Transmission: 722643 06 344770
Engine
Major assembly variant: A 113 010 72 44
SA code
040U BLACK
07N STEUERCODE WERK SINDELFINGEN/GRAZ
212B OP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA/CAN
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING
221B SIGN COOLANT/REFUELING - ENGLISH
232 GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY
242 FRONT SEAT RH ELECTRIC ADJUSTABLE WITH MEMORY
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
250A LEATHER
264 LICENSE PLATE ATTACHMENT AMERICA
265 LINES-NO.PLATE DISCONTINUED
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
284B AIRBAG LABEL - ENGLISH FOR USA
293 SIDEBAG IN REAR LEFT AND RIGHT
301 ASHTRAY PACKAGE
309 CUP HOLDER
359 LOW COST TELEAID USA
404 MULTI-CONTOUR SEAT, FRONT LEFT
405 MULTI-CONTOUR SEAT, FRONT RIGHT
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
423 5-SPEED AUTOMATIC TRANSMISSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
489 AIRMATIC DUAL CONTROL / AIR SUSPENSION SEMI-ACTIVE
494 U.S. VERSION
49N STEUERCODE WERK SINDELFINGEN/GRAZ
524 PRODUCT PROT. F.PAINT - TRANSPORT VEH.PRESERVATION
528 COMAND DVD PLUS (WITHOUT NAVIGATION)
543 SUN VISOR WITH ADDITIONAL FUNCTION
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
581 AUTOMATIC CLIMATE CONTROL
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
668 PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
669 SPARE WHEEL / FOLDING WHEEL
673 HIGH-CAPACITY BATTERY
705L UNITED STATES (USA)
732 BIRDS EYE MAPLE WOOD FINISH
763 RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
786 AMG DOUBLE-SPOKE WHEELS 18" WITH MIXED TIRES
7XXL NORTH AND SOUTH AMERICA
806 YOM 05/1/M; 15/1/M/X
810 SOUND SYSTEM
819 CD CHANGER
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
875 HEATED SCREEN WASH SYSTEM
910 DYNAMO WITH HIGHER CAPACITY (FFO)
915 FUEL TANK WITH LARGER CAPACITY
919 AIRCON COOLING POWER PACKAGE
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
986 IDENTIFICATION NUMBER (VIN-NO.)
989 IDENTIFICATION LABEL UNDER WINDSHIELD
M001 ENGINES WITH SUPERCHARGER
M113 V8-GASOLINE ENGINE M113
M55 CAPACITY 5,5 LITRE
Y88 ORION GRAY ALCANTARA HEADLINER
#570
Hey Rodney,
Thanks in advance,
AL
Thanks in advance,
AL
Datacard
Identification number: WDD2163711A003457 1
VIN: WDDEJ71X17A003457
Chassis
Sales designation: CL 550
Order number: 0 7 701 20225
Delivery date: 24 11 2006
Paint code 1: 775U BRIGHT SILVER METALLIC CLEAR COAT PAINT
Equipment: 801A LEATHER/NAPPA/SEMI-ANILINE - BLACK/ANTHRACITE
Engine no.: 273961 30 110033
Transmission: 722904 01 000614
Engine
Major assembly variant: A 273 010 00 02
Part var. design.: 27396130
Text 5,5 LTR / V 8 MOTOR IM F216/221
BITTE BASISMOTOR A273010820080 BESTELLEN.
HINWEIS BASISMOTOR BEACHTEN.
ORDER PLEASE BASIS ENGINE A273010820080.
REFERNCE BASIS COMBUSTION ENGINE CONSIDER.
SA code
218 REAR-VIEW CAMERA
229 PARK ASSIST
233 AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
267 TYPE-DESIGNATION DEVIATING
285B AIRBAG LABEL - ENGLISH / FRENCH FOR CANADA
289 LEATHER STEERING WHEEL WITH TRIM INSERT
294 KNEE AIRBAG
301 ASHTRAY PACKAGE
310 DUAL CUP HOLDER
389 MOBILE PRE.-INSTALLATION (MTUS) USA/CANADA COMPL.
396 LINGUATRONIC-AMERICAN
401 FRONT SEAT CLIMATE CONTROL
427 AUTOMATIC TRANSMISSION 7-SPEED
432 DYNAMICS SEAT,FRONT LEFT AND RIGHT
435 HEAD RESTRAINTS,REAR, PNEUMAT.FOLDING UP/DOWN
443 HEATED STEERING WHEEL
460 KANADA-AUSFUEHRUNG / ZUSATZTEILE
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
494 U.S. VERSION
530 COMAND DVD APS USA WITH NAVIGATION
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
610 NIGHT VISION SYSTEM
615 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
619 CORNERING ILLUMINATION
690 EMERGENCY SPARE TIRE (MINI SPARE)
701L CANADA
731 WOOD TRIM BURRED WALNUT ROOT
770 AMG 19" SPOKED WHEELS WITH MIXED TIRES
800A LEATHER/NAPPA/SEMI-ANILINE
807 YOM 06/1/M/X; 16/1/M/X
810 SOUND SYSTEM
814 DVD CHANGER
876 INTERIOR LIGHT ASSEMBLY
881 REMOTE TRUNK LOCKING
889 KEYLESS - GO
91V SPEED- + LOADINDEX 96Y+101Y
A21 SHIFT BY WIRE
A22 NEW CONVERTER GENERATION
A24 JOINT FLANGE, 4-ARM 120
A45 O-SHIFT PLATE WITH VGS2
K12 STEUERCODE FUER SERVICEINTERVALL
K14 STEUERCODE FUER SERVICEINTERVALL 20000 KM
M273 V8-GASOLINE ENGINE M273
R01 SUMMER TIRES
U12 FLOOR MATS, VELOURS
U71 DVD PLAYER WITH REGIONAL CODE 1, USA
#571
#573
so im thinking about buying a 2007 c280 4matic. i narrowed my search down to two that i really like so far. one has 90k and the other has 100k. can i expect this car to last awhile? i drive maybe 18k miles a year. also can someone check these vin# and see if they have the engine shaft problem that everyones talking about.
WDBRF92H97F925783 (100,000 miles)
WDBRF92H17F930878 (90,000 miles)
thanks in advance
thanks in advance
#574
MBworld Guru
WDBRF92H97F925783 has M272 #590228.
WDBRF92H17F930878 has M272 #580258.
Both are beyond the range for balance shaft issues.
#575
is this 2009 ML350 within the range of the balance shaft issue?
4JGBB86E39A528350
4JGBB86E39A528350
