Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old 03-28-2014, 10:46 AM
  #601
vastcre's Avatar
none
Rodney, thanks again for this. I'm looking at a 2007 c320 with VIN: WDBRF52H97A935378. Is this in the range for problems?
Old 03-28-2014, 11:57 AM
  #602
MBworld Guru
Rudeney's Avatar
Received 1,002 Likes on 870 Posts
NO LONGER ACTIVE
WDBRF52H97A935378 has M272 engine #450381, which is in the affected range.
Old 03-29-2014, 05:32 PM
  #603
pootie1's Avatar
2000 Mercedes c230 Kompressor
Rodney, I'm interested in buying a 2006 slk280 and am worried about cam shaft problems. Can you check the vin on the one I'm considering? It would be much appreciated! WDBWK54F26F127482
Travis
Old 03-30-2014, 12:36 AM
  #604
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBWK54F26F127482 has M272 engine #360439, which is in the affected range (all MY2006's will fall into the affected range).
Old 03-30-2014, 12:53 AM
  #605
pootie1's Avatar
Rodney, thank you do much for helping me avoid a possible disaster! Such a shame for such a beautiful car.
Travis
Old 04-01-2014, 10:53 PM
  #606
vastcre's Avatar
none
Rodney,thanks again. How about a 07 c280 VIN WDBRF92J27F907984
Old 04-02-2014, 09:41 PM
  #607
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBRF92J27F907984 has M272 engine # 558999 - it's good, beyond the affected range.
Old 04-02-2014, 11:24 PM
  #608
Seany402's Avatar
C280 4matic
07 c280 4matic
Hey guys. New to the thread and site. Looking at a c280 and came across this balance shaft thread. The vin for the one I'm looking at is WDBRF92H37F919722. I would be very appreciative if someone would check to see if it falls with in range. Thank you!
Old 04-02-2014, 11:30 PM
  #609
Seany402's Avatar
C280 4matic
Also, I haven't seen anyone ask, if I can verify the balance shaft has been replaced does that mean I'm good or should I still stay away? Thank you!
Old 04-03-2014, 11:22 AM
  #610
coopershawk's Avatar
2007 C280
Hi Rodney,
I'm looking at a 2007 C280 with the following VIN:
WDBRF92H57F889008
Is it within the affected range?
Thanks in advance!
Old 04-03-2014, 10:25 PM
  #611
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBRF92H37F919722 has M272 #577718 - it's beyond the affected range.
WDBRF92H57F889008 has M272 #516347 - also beyond the affected range.
@SEAN: Yes, if you can verify that the balance shaft (or idler gear on the M273 V8) has been replaced, then that is a permanent fix.
Old 04-04-2014, 09:27 AM
  #612
2007 C280
Many thanks Rodney!
Old 04-08-2014, 12:46 PM
  #613
YeomanC230's Avatar
Mercedes c230
Old 04-08-2014, 12:51 PM
  #614
YeomanC230's Avatar
Mercedes c230
Crossing my fingers
Could someone please check my vin??
I bought a 2007 C230... would you please be so kind to look up the vin if it has issue...
my vin is WDBRF52H47A933571
Thank you so much
Ed
Old 04-08-2014, 09:04 PM
  #615
vastcre's Avatar
none
Thanks as always Rodney. I'm now looking at a 2005 C class vin # WDBRF40J35F722250. Balance shaft?
Old 04-09-2014, 12:35 AM
  #616
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBRF52H47A933571 has M272 engine #446023, which is in the range for potential balance shaft failure.
WDBRF40J35F722250 is a C230 Kompressor - no worries there with balance shaft issues on the M271 engines.
Old 04-09-2014, 10:36 AM
  #617
vastcre's Avatar
none
What about an '03 C320 vin# WDBRF84J23F384368?
Old 04-09-2014, 11:40 AM
  #618
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
rudeney...
can you do the honors...looking to buy this vin...WDBUF87X67X216873...
coming from a w203 and looking to buy this 2007 E350...103kmiles...
thanks
javvy
Old 04-10-2014, 12:29 PM
  #619
pootie1's Avatar
Rodney,
Can u check this vin please?
WDBWK5477F161080
Thanks!
Travis
Old 04-10-2014, 11:09 PM
  #620
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Your MY2003 C230 has the M112 engine - no balance shaft issues on those.
Old 04-10-2014, 11:11 PM
  #621
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by Javvy
rudeney...
thanks
javvy
That has M272 engine #474516 - it is beyond the affected range (ended with #468993)
Old 04-10-2014, 11:14 PM
  #622
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by pootie1
Rodney,
WDBWK5477F161080
Thanks!
Travis
Hi Travis, i think you left out something in that VIN - maybe a letter between "54" and "77"?
Old 04-10-2014, 11:48 PM
  #623
pootie1's Avatar
So sorry Rodney. It the letter "F" between the 54 and 77. Thanks!
Old 04-12-2014, 12:12 AM
  #624
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
OK, WDBWK54F77F161080 has M272 engine #597397 - it's beyond the balance shaft problem range.
EDIT: Fixed the VIN
Old 04-12-2014, 12:28 AM
  #625
pootie1's Avatar
Rodney,
The vin reads as follows...
WDBWK54F77F161080
I think the "F" was in the wrong place.
Thanks so much!
Travis
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: Please check my VIN for Balance shaft issue?
