Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old 04-12-2014, 09:59 AM
  #626
MBworld Guru
Rudeney's Avatar
Received 1,004 Likes on 872 Posts
NO LONGER ACTIVE
Originally Posted by pootie1
Rodney,
The vin reads as follows...
WDBWK54F77F161080
I think the "F" was in the wrong place.
Thanks so much!
Travis
Yep - see above ^^^ I just pasted the original VIN you had without the "F",but put it in EPC when I did the search, so that's it (so yours is good).
Old 04-14-2014, 11:42 PM
  #627
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDDGF5EB8AR104100 has M272 #31-355684. It is far beyond the affected range. The W204 will not be affected, nor will any MY2010 - the problem range are M272 engines through mid-MY2007.
Old 04-16-2014, 08:29 AM
  #628
mbfane350's Avatar
06 e350 and 08 ml350
I've got 06 e350 vin # WDBUF87J96X198539
Very much appreciated!
Old 04-16-2014, 10:25 PM
  #629
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBUF87J96X198539 is a MY2006 - so you know the engine will be in the range for possible failure - it's M272 #230723.
Old 04-21-2014, 04:30 PM
  #630
rg1977's Avatar
2007 CLK550
Hi Rodney.
2007 CLK550
WDBTJ72HB7F219610
Much appreciated that you take time out of your day to help people out...for free.
Old 04-21-2014, 07:13 PM
  #631
Monk's Avatar
C320
2008 CLK350
WDBTJ56H38F245161
Please check to see if this issue affects this car.
Old 04-21-2014, 10:46 PM
  #632
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by rg1977
Hi Rodney.
2007 CLK550
WDBTJ72HB7F219610
I think that 9th digit is an "8" not a "B". If so, then you have M273 engine #111251, which is beyond the problem range.
And no worries about the time, it takes me literally just a few seconds to cut and paste a VIN into EPC to get the engine serial number.
Old 04-21-2014, 10:47 PM
  #633
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by Monk
2008 CLK350
WDBTJ56H38F245161
No worries with a MY2008 - you have M272 engine #791297, which is beyond the affected range.
Old 04-28-2014, 12:03 PM
  #634
MaconPerformanc's Avatar
2006 CLK500 vert
Whats up guys? I just purchased a 2006 Mercedes CLK500 and Its my first mercedes. I have been a Honda and Acura buff for so long. I really want to lower it and put some wheels on it...only thing is it rides so well.... Rudeney seems to know a lot about these cars. What could I do to make the car look a little more sporty? Oh yea, my car has a SRS light on...thats about it.
Old 05-01-2014, 09:38 AM
  #635
petez1125's Avatar
2007 E350 4 Matic Silver/Ash and 2005 C55 Black/Black
I am in the process of looking at a 2007 E350 4-matic.
Here is the VIN WDBUF87X67B172466
Can someone tell me in the engine is within the range of the bad balance shaft? It would be greatly appreciated.
Pete
Old 05-01-2014, 09:48 PM
  #636
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBUF87X67B172466 has M272 engine #649466 - it's well beyond the range for balance shaft problems.
Old 05-02-2014, 05:56 AM
  #637
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Welcome, may want to do some searching, both of these topics are well covered...wheels are a good start and lots have lowered... I just had my 3 resonators deleted (some call 2 of them secondary cats).. Exhaust sounds much better...good luck...and id start your own thread if you have specific questions
Old 05-02-2014, 10:16 AM
  #638
petez1125's Avatar
Rudeney, thanks so much for checking.
Old 05-02-2014, 02:35 PM
  #639
2006 CLK500 vert
Here is my VIN# - help me out
WDBTK75G96T067725 - thanks in advance for checking
Old 05-03-2014, 02:55 PM
  #640
cbp24's Avatar
2012 BMW 335
Looking at 2009 CLK 550 and worried about issues discussed above. Can you please check the VIN and let me know if the car is in the range of balance shaft and or idle gear problems:
WDBTK72F09T103866. Car has 66,437 miles if that makes any difference. Thank you so much.
Old 05-03-2014, 11:11 PM
  #641
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
No worries at all about the balance shaft on a MY2009 - WDBTK72F09T103866 has M273 engine #289440 - way beyond the affected range.
Old 05-03-2014, 11:30 PM
  #642
cbp24's Avatar
2012 BMW 335
Thanks so much. Any idle gear issues with this one?
Old 05-04-2014, 12:34 PM
  #643
AMG_Adon's Avatar
05 E55
2009 CLK550
WDBTJ72H79F260121
wanted to know if I will be affected by the balance shift issue . thanks
Old 05-04-2014, 01:25 PM
  #644
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
No - the last M273 engine for idler gear failure was #88611. And when we say "balance shaft failure", what we really mean is "timing chain idler sprocket failure". On the M272 V6, the idler sprocket is a forged part of the balance shaft. It does double-duty by driving the balance shaft and "idling" the timing chain where it runs down to the bottom of the "V" between the camshafts. On the M273 V8, it has no balance shaft (it's not needed as V8's are inherently balanced) so the sprocket is just bolted onto the engine block to "idle" the chain.
Old 05-04-2014, 04:26 PM
  #645
cbp24's Avatar
2012 BMW 335
Rodney: I really appreciate your clarification. Was afraid of this car due to previous issues. I'll give it serious consideration now.
Old 05-05-2014, 04:45 PM
  #646
petez1125's Avatar
Rodney, can you check one more VIN for me? The car I was looking at has a bunch of issues such as the intake manifold tumbler being broken. My service advisor has recommend looking at another vehicle.
Can you check this VIN for me: WDBUF87X39B383000
Old 05-05-2014, 10:10 PM
  #647
scoopers1275's Avatar
06 E350
Rodney, I own a 06 E350 that has 118,000 miles on it now.
WDBUF87JI6X195327.
I am looking at a 06 CLK350 with only 89,000 miles.
WDBTJ56J66F170777.
Am I living dangerously here? I didn't even know about this balance shaft failure until I started looking round for the CLK.
Your help gratefully appreciated.
Thanks.
Stephen
Old 05-05-2014, 11:32 PM
  #648
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBUF87X39B383000 has M272 engine #31-043601 - as expected with a MY2009 - it's way far beyond the affected range.
WDBUF87J16X195327 has M272 engine #192864 which is in the range (MY2006 will be) as is WDBTJ56J66F170777 with M272 #104728.
Old 05-06-2014, 04:15 AM
  #649
cooly15's Avatar
2002 C230 Coupe
hi there,
I am looking to get a used 2008 C350.
VIN: WDD2040562A234868
Engine #: 27296131114946
"M272 engines that were sold between 2004[1][2] and 2008 with engine serial numbers below 2729..30 468993" from wiki.
Am i safe from the issue? Thank you
Old 05-06-2014, 10:07 PM
  #650
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, your engine is "31-114946", and as expected with a MY2008, it's well beyond the affected range.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: Please check my VIN for Balance shaft issue?
