Please check my VIN for Balance shaft issue?
Also heard that the 7speed tiptronic in it has had issues in that model?
Thanks!
As for transmission issues, the earlier 722.9's do tend to be more problematic. a common issue is a bad turbine speed sensor that takes out the conductor plate.
4JGBB86E57A257191
If that's correct, then it has M272 engine #603288, which is beyond the balance shaft problem range.
Thank you very much!
M113 .... Are they supject for any of these issues?
I am looking at a 2007 C280 and I would be grateful if you would check the following VIN:
WDBRF54H37F935179
Thanks in advance!
WDBRF54H37F935179
Thanks in advance!
VIN WDBUF42H06A945283
thanks
WDBRF92H27F927794
Thanks for the help
