Please check my VIN for Balance shaft issue?
Old Jun 2, 2015 | 09:55 AM
  #1101
hcuellart's Avatar
W209 CLK500
Just bought a 2005 CLK500
Hello guys new here but wanted to check with you about the shaft issue...
VIN WDBTK75J25F121553
Thanks for your help it is much appreciated!!
Regards,
Homero
Old Jun 2, 2015 | 11:59 PM
  #1102
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
A MY2005 CLK500 has an M113 engine - not affected.
Old Jun 3, 2015 | 10:51 AM
  #1103
hcuellart's Avatar
W209 CLK500
Thanks Rodney!!
Old Jun 12, 2015 | 07:14 PM
  #1104
Jeanimead's Avatar
2006 e class wagon/ 2008 accord
VIN check for balance shaft 2007 e350 wagon
Could you please check this VIN and let me know if it's in the affected range for balance shaft failure. WDBUH87X37B137099
Old Jun 12, 2015 | 10:39 PM
  #1105
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
M272 engine #609907 - well beyond the balance shaft problem range.
Old Jun 15, 2015 | 08:48 AM
  #1106
George4541's Avatar
2006 ML350
Engine number
Can someone please check my vin number for balance shaft problems. It's an ML350 with vin number 4JGBB86E36A101794
Old Jun 15, 2015 | 02:04 PM
  #1107
TechSuperstar's Avatar
15' CLS400
Originally Posted by Kory_Denver
Would you please check WDBRF87H86F805068
I just bought this C350 and according to carfax report Camshaft adjuster solenoid was replaced at 95k. Is it something related with this problem? The car now has 112k . what are symptoms for balance shaft issues?
Thank you
I think the solenoid's reporting issues is a sign that your starting to have balance shaft issues. I don't know how they're linked but my car reported bad solenoids (two at the same time, then one of the replaced ones again a few weeks later) just before it was determined I had the balance shaft issue. Coincidence?
Also, although my car was done years ago now I just received the class action lawsuit paperwork in the mail a few weeks ago.. From reading it, it looks like they're taking care of all cars whether their out of warranty or not. Let me say, if they are indeed taking care of people then in my opinion its worth buying a car that hasn't had it done yet. Why? Because they have to remove the engine and in doing so ALL of the liquids.. Your basically getting a full 100k mi service done for free, change the spark plugs and your all set.
Old Jun 15, 2015 | 11:22 PM
  #1108
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That's a MY2006 - as will all xx350's it will have an M272 engine in the range for potential balance shaft failure.
Old Jun 15, 2015 | 11:28 PM
  #1109
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Camshaft adjuster solenoid failure and balance shaft failure have nothing in common except that there is an overlap in the range of engine serial numbers that are afflicted by both problems.
The class action settlement will only pay a percentage of the repairs. If the repair has already been performed and you paid for it out of pocket, then you may get a percentage of that back from MBUSA.
Old Jun 18, 2015 | 07:10 AM
  #1110
CaLvinK86's Avatar
Clk280
Engine chexk
Hi guys,
Could someone with access please check my VIN:
I just got a CLK280 06
WDB2093542F179570
Many thanks in advance
Old Jun 18, 2015 | 08:36 PM
  #1111
barnett.jh@gmai's Avatar
2007 c230
need VIN check WDBRF52H97F901458 balance shaft issue
Help greatly appreciated
2007 C230
Old Jun 18, 2015 | 11:09 PM
  #1112
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by CaLvinK86
Hi guys,
WDB2093542F179570
All MY2006's with the M272 enigne (as in your CLK280) will be "in the range" for potential balance shaft failure. Only MY2007 needs to be checked as it was fixed midway through that build cycle.
Old Jun 18, 2015 | 11:11 PM
  #1113
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
2007 C230
M272 #548190 - beyond the balance shaft problem range.
Old Jun 19, 2015 | 09:37 AM
  #1114
2007 c230
Thank you Rodney
I am looking at buying C230 with 87,000 miles for $10.777. Are there other issues I should be aware of. What used models are looking like they may go higher miles. I am willing to go as high as $20.000 plus for later model and lower mileage. My 1999 C230 went 225 K miles and was relatively hassle free. Any suggestions?
Old Jun 19, 2015 | 09:50 PM
  #1115
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There are more problems with earlier (pre-2009) 722.9 7GTRONIC transmissions. Otherwise, it's as as solid as any other W203.
Old Jun 19, 2015 | 10:59 PM
  #1116
Jsamayoa's Avatar
Mercedes benz ml 350
Mercedes ml350
Hi Rodney can you kindly check if this 2006 ml350 is in the range please
4JGBB86E06A065885
Thanks a lot
Old Jun 20, 2015 | 12:25 AM
  #1117
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
4JGBB86E06A065885
Thanks a lot
All MY2006 vehicles with the M272 engine (xx230, xx280, xx300, xx350) will be "in the range" for potential balance shaft failure. Only MY2007 needs to be checked as it was halfway through that build when the problem was found and corrected.
Old Jun 20, 2015 | 07:47 PM
  #1118
Jsamayoa's Avatar
Mercedes ml350 2008
Hi Rodney please help me planning to purchase the ml 350 2008 can you check this vin 4JGBB86E58A309856
Old Jun 20, 2015 | 11:16 PM
  #1119
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MY2008s will be beyond the balance shaft problems. Only MY2007s need to be checked as it was halfway through that build when the problem was discovered and resolved.
Old Jun 21, 2015 | 03:59 PM
  #1120
Jonnyjayhawk's Avatar
C280
1
Figured it out.
Old Jun 21, 2015 | 08:16 PM
  #1121
eskscott's Avatar
2005 clk500
Rodney,
New member here. You seem to be pretty versed on this subject. Can you check my vin #
WDBTJ75J75F146385
Old Jun 21, 2015 | 09:43 PM
  #1122
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by eskscott
Rodney,
WDBTJ75J75F146385
There are no balance shaft worries with the CLK500 - it has the M113 engine that did not have the problem.
Old Jun 22, 2015 | 11:47 AM
  #1123
BENGLER8@GMAIL.'s Avatar
C280
balance shaft gear
I am also jumping in to the seemingly long thread on the balance Shaft Gear.
My VIN is WDBRF92H57F840004
I am looking to buy this vehicle, a 2007 C280.
Any help please? This is my first post and I am not sure I am posting correctly.
Is this car's in the affected range? I went on a web site to discover engine number, but it wanted me to pay for the info?
Thank you any one!
Bill
Kansas City, MO
Old Jun 22, 2015 | 09:49 PM
  #1124
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I replied to your PM - it's in the range.
Old Jun 24, 2015 | 03:34 PM
  #1125
melissa1984's Avatar
c230 mercedes
I may be another victom
My first and last mercedes. I would like to know if I could be in the . group with a faulty sway bar. Here is my vin...
WDBRF52H96A905313
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
