2005 CLK320 cabriolet with power steering noise
Old Oct 11, 2012 | 08:20 AM
sleepy hollow's Avatar
2005 CLK320 Cabriolet
Car has about 60K miles.
I tried to find the reservoir but could not locate. Owner's manual says bring it to the dealer. Arg!
It has more of a low pitched growl to it, as opposed to a higher pitched whine. Also a slight vibration that I can feel in the wheel as I turn it.
I am pretty handy, have done quite a few major repairs, but never changed a steering rack.
Suggestions on how to diagnose or am I stuck heading to the dealer to help him pay his mortgage?
Thanks.
Old Oct 11, 2012 | 09:00 AM
Glyn M Ruck's Avatar
Super Moderator
The reservoir is below the RH air inlet pipe. Pull off pipe to access. Make sure fluid level is correct before doing anything. Does it make more noise at full lock?
Old Oct 15, 2012 | 10:21 AM
Thanks so much for your post. Stupid me, I did not bother to look for it, but believed the manual.
Well I had to bring it to the dealer for service anyway, and he informed me that it was the water pump.
Also, they tell me the valve cover is leaking profusely. Neither of these speaks well for the vaunted Mercedes engineering.
Is this normal for a car that only has 63K on it?
Old Oct 15, 2012 | 11:05 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There seems to be a rash of water pump failures lately. It's not a common problem, but it does happen like with any mechanical part. On the valve cover gaskets, yes, they tend to leak as mileage increases. It's usually not a problem with the gasket, but the breather covers and hoses get clogged and pressure builds in the crank case so the oil has to go somewhere. While just cleaning the breather covers might work, it's really not such a bad job to replace the gaskets and clean everything well. I can do it in a few hours, and the parts are about $30. Oh, and use genuine MBZ gaskets - the Victor Reinz gaskets are too small and will leak from day one.
Old Oct 16, 2012 | 08:41 AM
Thanks for your follow up.
Now they tell me that my front bearings need to be replaced.
This is something I believe I can do myself. Appreciate any thoughts you might have. They want $600 to do them.
Old Oct 16, 2012 | 01:13 PM
DangermouseCLK's Avatar
2005 CLK 320
FWIW, my 05 CLK320 had the valve covers done by the PO at 47k.
Old Oct 16, 2012 | 09:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
"Maybe". It requires some special tools, though you may be able to rent them or "rig" something to work.
Old Oct 17, 2012 | 10:38 AM
Super Moderator
See Wiki.
https://mbworld.org/wiki/images/1/15..._wheel_hub.pdf
