MB Fuel Additive
Old Dec 28, 2012 | 09:56 AM
mis3's Avatar
2004 CLK320
MB Fuel Additive
I was int he dealership talking to the parts guy. He recommended a MB fuel additive (part: 000-989-25-45-12), he said this is better than the Chevron. I bought a bottle for $10 and the bottle says "Made in Germany" and it is only 3.4 fl. oz.
I learnt about Chevron Fuel System Cleaner from this forum and I have been using it for the last 3 years.
Did anyone here try this MB fuel additive?
Old Dec 28, 2012 | 12:11 PM
Glyn M Ruck's Avatar
Super Moderator
I hate to burst his bubble but it is the same thing. There are only 2 approved systems from Chevron & BASF & they are the same thing. You can buy them as a Benz PN. I'll bet it's more expensive from the dealer.
Old Dec 28, 2012 | 12:57 PM
CLK550 $wagger's Avatar
White CLK550
http://shop.advanceautoparts.com/web...ontent=7080568
Glyn Is this the stuff you are taking about using?
If so, how much do you use and how often would you recommend using it?
Old Dec 28, 2012 | 04:08 PM
Super Moderator
Yes, that is the stuff.
If you are using tier one fuel then maybe in one tank every 5000 miles. Max gap once every 10K miles.
Old Dec 28, 2012 | 08:12 PM
mis3's Avatar
2004 CLK320
Not surprised.
Maybe this MB additive is more concentrated. It is only 3.4 oz and it says it will treat 67 liters of gas. Chevron additive is 20 oz and treats similar amount of gas.
I was told that it's best to add this kind of additives before a long trip. The injectors will be cleaned better with a constant flow of fuel. Is this correct?
By the way, my friend has bought me some Chevron Fuel System Cleaner from Autozone (Manchester, NH), $24 for a set of 4. I will get them next week.
Old Dec 29, 2012 | 08:16 AM
Super Moderator
No that is wrong. The product works best in in a lot of start, warm up, stop driving. The more heat soak cycles the better it works.
It will still work on a long run but the action is slower. Cleaning injectors is the easy part ~ they build very light deposits & Techron removes them very quickly. Inlet system, valve tulips & combustion chambers are the hard to clean places.
Old Dec 29, 2012 | 08:54 AM
Peydidy's Avatar
C63 AMG
90% of the time when I get gas I fill up at a chevron station and it always says "chevron with techron" Do I still need to put in fuel additive or will filling up with chevron do the same?
Old Dec 29, 2012 | 09:24 AM
Super Moderator
Filling up with Chevron will do the same. Giving it a boost with concentrate every now & then will do no harm but if you run Techron fuel all the time it will clean up & keep clean.
Old Dec 29, 2012 | 11:50 AM
mis3's Avatar
2004 CLK320
Good to know; I will do this for city driving.
The Chevron I used is the fuel system cleaner. Hope it will clean the rest of the fuel system as well.
Old Dec 29, 2012 | 12:03 PM
mis3's Avatar
2004 CLK320
Good to know; I will do this treatment for city driving.
Old Mar 28, 2013 | 03:37 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Glyn, what do you mean by max gap 10K miles?
I'm gonna buy some 20oz bottles. I've never actually used this stuff before on any of our cars.
Also, I usually use Shell, 76/conoco phillips, exxon/mobil (in that order for most often to least often). How often you think I should use it? Also, my father has an 02 CL500 which he just puts Arco/Bp (I always tell him not too, but he says it's all the same). How often would you recommend for that car?
