How often do you change your oil?
I think you can go up to 13K - that's the service interval on my cluster. I never would. That would be nearly two years for me. I do it once a year, which is probably about every 8. If I drove more so the time interval was less, I'd probably go 10k, but no more.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Once a year or every 15,000Km's / 10,000 miles. As per Service Indicator ~ Mobilodrive Plan.
MBworld Guru
I change mine according to the service indicator on the MFD - I have done this on every modern MBZ I've owned. I use the recommended Mobil 1 oil and Mann synthetic fleece filter. FYI, if you drive less than 13K miles per year, the MFD will still have you perform a service at least once per year.
Super Moderator
Did final Benz CLK's to the US have the service interval reduced from 13K miles to 10K miles like the W204?
Super Moderator
On the 203 forum Mobil 1 0W-40 Euro formulation 229.5 usually looks fine at 13K miles other than having sheared slightly out of grade & become a high 0W-30.
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
When you say that does time does the cluster read XX Days left ? Mine is reading 7 days left for next service and I only have had maybe 5k miles on it since the last service and that was service B. If thats the case and i just do a reset on the cluster and wait till next time. ?
Yeah, Blackstone. Said something like the TBN value being low (1.6).
Super Moderator
Super Moderator
Hmm! Virgin Mobil 1 0W-40 has a TBN of 12.5. I wonder why your result was so low. TBN is the reserve alkalinity in an oil to offset acidic by-products of the combustion process. It is not really of any great consequence with gasoline engines because gasoline contains very little sulphur.
It is of great consequence with diesel engines due to high sulphur levels in diesel fuel.
MBworld Guru
Having said that, I think the CLK is going to be right at the miles this time as I've done more driving this last year. I changed jobs last January and added about 30 miles a day to my commute, plus going out to lunch was a longer drive. Luckily, I left that place in November, so my mileage should go back to "normal" this year.
