Leather shift boot replaceable?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Mar 17, 2013 | 04:01 PM
Yidney's Avatar
2008 CLK550 Cab
Is the leater shift boot replaceable separately or is it part of the shift knob? I just pulled my shifter off and I cant see how the boot would detach at the top - it seems permanently fastened.
Old Mar 17, 2013 | 06:30 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MBZ only sells it as one piece - part number A2032671811 + color code (w/o KelylessGo). I think it's around $200. However, it is possible to remove the leather boot from the shift knob - Jerry has instructions here:
http://www.formymercedes.com/Shift_K...ather_Boot.asp
I'm not sure what good it will do, though, unless you are going to have a leather shop make a new boot for you.
Old Apr 4, 2017 | 01:43 AM
COOPERDB's Avatar
NB8 PARACHUTE
Does anyone (Rodney) know if the above part #
would be the same for a 2003 CLK500
Thank-You
D.B.
Old Apr 4, 2017 | 02:12 AM
Yidney's Avatar
2008 CLK550 Cab
Coincidentally, I just priced this today - with keyless go. It was $400+.
Old Apr 4, 2017 | 11:26 AM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
Thank-You
D.B.
Part # should be the same, but most likely it's going to be slightly different shifter knob (with MB emblem on the top).
Old Apr 4, 2017 | 11:31 AM
dzmitry's Avatar
I'm pretty sure that you can buy one w/o keyless go and replace only shift boot from (without shift knob). Actually I have spare shifter from version with keyless go (from 2005 clk) I can double check that shift boots are the same.
Old Apr 4, 2017 | 09:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The boots will be the same. It's fairly easy to remove it from the knob:
http://formymercedes.com/Shift_Knob_...ather_Boot.asp
Old Apr 4, 2017 | 09:15 PM
ItalianJoe1's Avatar
2003 CL 600
Someone should send a stock one to Redline Goods if it hasn't been done, and get it templated for real leather replacement boots. They would hold up better too.
Old Apr 4, 2017 | 11:17 PM
COOPERDB's Avatar
NB8 PARACHUTE
I am looking to purchase as per
the above part# in black (boot and knob)
I would guess that Redline already has
this boot pattern but if not...
Thank-You
D.B.
Old Apr 5, 2017 | 01:30 PM
eteller's Avatar
2009 CLK 350
+1 on Redline, good stuff.
Old Apr 5, 2017 | 05:03 PM
COOPERDB's Avatar
NB8 PARACHUTE
I just placed an order with Jerry at
http://formymercedes.com/clk-classW209.asp
for something else
He took the order over the phone and is getting
it in the mail today
Every order with him the service is excellent
and the shipping fast
Thank-You
D.B.
Old Apr 5, 2017 | 06:47 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Jerry's a good guy - been a customer for years. As for getting a boot custom made, use the OEM as a template and then have them add about half an inch in height to relieve some of the stress on the chrome trim ring!
Old Apr 6, 2017 | 09:02 AM
sailorben's Avatar
CLK W209
Very true Rodney. Mine is now having to be glued down, and while the blue dries to full strength, it can't be driven as the boot is too tight, thus moves the trim piece. Silly!
Old Apr 6, 2017 | 07:04 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I fixed mine with screws under the wood panel:
Old Apr 8, 2017 | 01:01 AM
COOPERDB's Avatar
NB8 PARACHUTE
for something else
I placed my order on the phone at 2pm Wensday
so it would be 4pm Chicago time
I received my package this morning at 10:30am
All Jerry told me was - I'll get it in the mail today
Super fast shipping
Thank-You
D.B.
Old Apr 9, 2017 | 12:32 PM
sailorben's Avatar
CLK W209
I was trying to picture how you had done this. I may well do similar next time I have to lift that piece.
Old Apr 9, 2017 | 02:23 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The only issue with my repair is that you can no longer pop the boot off the shifter when you need to remove the center console panel. Instead, you have to lift up on the whole panel with the boot in place, then pull it up over the shifter and release the locking collar and remove the knob so you can then fully remove the panel. It's a minor inconvenience, though, since one would not be disassembling the console very often (or so I'd guess).
Old Apr 12, 2017 | 12:19 AM
COOPERDB's Avatar
NB8 PARACHUTE
Yes - picked it up from from the dealer today
In black with the MB emblem
I then drove to Eastside Auto Salon (EAS) in
Bellevue where luck was with me as the overhead
door was open and I drove right in
It took Ben about 3 minutes to remove the old
knob/boot and install the new one
Looks great - glad I did it
Thank-You
D.B.
Old Apr 12, 2017 | 12:25 AM
dzmitry's Avatar
Thank-You
D.B.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
