Interior Temp Sensor replacement...$$$$?
http://www.parts.com/parts/index.cfm...earch&siteid=2
Thanks!
Thanks for your quick reply. I double checked the windows and they are closed all the way.
When Safelite (Yes, Safelite) left I had trouble opening the top. The top was stuck in the front. I finally got it open and I carefully lubed the Pins and mechanism at the top of the winshield. I also noticed that the weather strip was not seated correctly...so I reinstalled it and fixed that part. I also noticed that the trim on the pillars were not seated corrected and I re seated them. So now the top opens and closes without an issue. The windshield tech had removed and reinstalled all the trim in the top of the windshield by the sensor.
So I had no max air problem before the install and now I do....I don't believe this is a coincidence....I haven't called Safelite yet as I wanted to research first and be ready for when they tell me they did nothing wrong.
Regards,
Richard
Especially given all the other issues, I would definitely call Safelite back and tell them what's happening. You may need to get the ACC scanned for codes to see what's going on.
Did anyone find any more detailed info on the way in which this wiring and connector can be 'damaged' during a screen install and how it can be identified? T.I.A!!
