"static" on audio system, all sources....
I'm looking to replace the head unit anyway. Can anyone suggest what are some good-to-great units for '05 CLK-320, that: 1) fit in the dash without issues; 2) don't cost arm & leg; 3) have iPhone type connections (optional though). Appreciate the info
As for replacing the head unit, any double-DIN will fit. I don't have a favorite to recommend because they seem to change so often, but there are many great choices from Pioneer, Alpine, Kenwood, etc. Since you have the "facelift" interior, you need to find a CLK-specific faceplate - don't use the one sold generically for both the W203 and W209 as it will be slightly too wide to fit.
Even with a plug-and-play wiring harness, you will need to tap into the light and 12v at the cigarette lighter to get illumination and switched 12v power. Also, your Harmon-Kardon system will not have any analog audio wiring in the dash - it's fiber optic to the amp in the trunk, then analog from there to the speakers. This isn't terribly complicated - you just need to run some analog wiring from the dash to the trunk, then tie into the speakers there in place of the factory amp. There is plenty of room for wiring in the channels under the door sills.
My headunit started doing this yesterday. It sounds like it’s steadily modulating, but it doesn’t react to volume or motor RPM (I thought it may be voltage or alternator related). I’m putting my money on a ground or something, but want to check with the community.
I did have a code pop up that was current and stored when I was doing a DAS check - low voltage to the headunit and low voltage to the CD changer (I can look up the specific codes in the morning) but it does tend to go away on its own.
Any ideas?
