Broken side view mirror glass
Old Aug 13, 2013 | 11:45 AM
benz500clk's Avatar
500CLK 2005
My right side view mirror glass shattered. I want to buy just the glass and replace it. I do not know if I have side view mirror dimming or heater element.
How do I find out what my car was delivered with by just the VIN # W D B T K 7 5 J 6 5 F 1 4 4 9 6.
I would save lots of money by just replacing the glass, that is, if no dimming or heater element is installed.
Thank you
Old Aug 13, 2013 | 08:23 PM
tw2's Avatar
tw2
I got mine from ebay united kingdom. $15 and it was heated, no auto dimming. The fit wasn't perfect but it worked. Just needed w209 and the year to get it.
Old Aug 13, 2013 | 09:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
FYI, you are missing a digit in that VIN - there should be 6 digits after the last "F". Usually only the driver's side is dimmed, but both are heated. You can get a non-dimming, heated glass from parts.com (assuming you are in the USA) for under $100.
Old Aug 13, 2013 | 10:34 PM
benz500clk's Avatar
500CLK 2005
Driver side has auto dimming, but the right side doesn't. I just bouhgt the right side view mirror glass on ebay for $20. The part I bought doesn't come with heater element.
Old Aug 13, 2013 | 10:41 PM
benz500clk's Avatar
500CLK 2005
Rodney,
Yes! you are right! I'm missing a digit on that VIN#.
It should be 144396 after the last "F"
Old Aug 13, 2013 | 11:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's no big deal on the lack of heat if you don't drive in a lot of snow and ice. I'd probably not buy a heated glass if mine broke - we rarely get freezing precipitation here and besides that, I wouldn'd drive the CLK in it (that's what the wife's Jeep Grand Cherokee is for).
Old Aug 14, 2013 | 01:42 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Only the driver's side is dimming and even that you can put a non-dimming one like I did since it's much cheaper (kind of better now at night since I have tints). You can find used one's online for like 40 50 bucks, new ones are around a 100 or so. All of the mirrors have heating feature (at least here in the US. two little tabs on the back of the mirror that these two female connectors from the housing plug into)
Old Aug 14, 2013 | 02:13 PM
paul.gorringe's Avatar
2005 CLK500
Hi, did you have to modify any connections or wiring to fit a non-dimming mirror?
I have the dimming mirror which has gone all hazy due to failure of the dimming function and a replacement from a dealer is £360 !!!
Any help very much appreciated
Regards
Old Aug 14, 2013 | 05:05 PM
tw2's Avatar
tw2
No the wires clip straight on for the heater element. Just tape the dimming wires out the way.
Old Aug 15, 2013 | 02:27 AM
gaazmon's Avatar
Regards
exactly what tw2 said. no modification. i had the exact same thing happen to mine. the chemical had leaked out. the dimming wire is just a two prong plug and there was an empty space in my non-dimming mirror to just slide the plug into
Old Aug 15, 2013 | 02:50 AM
2005 CLK500
Thanks for your responses tw2 and gaazmon
I will order standard heated mirror now.
That has saved me a lot of money, thankyou
Old Aug 15, 2013 | 07:49 AM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
auto dimming is the way to go but it is pricey.
i think i paid like $250 for a new one
for some reason a gouge vs. the drivers side
