Question regarding 05 SLK55 6/4pot calipers
Old Nov 9, 2022 | 01:10 PM
MitaWdb's Avatar
Coupe
Hi,
Please, anybody can tell me if 340 mm rotors with 6 pot calipers fits with 17” wheels on Slk 55 AMG?
Thank you
Originally Posted by dzmitry
Front rotors: part # 1714210112, or directly Brembo part # 09.9254.33 (much, much cheaper) - 340mm
Front pads: they are the same for 360mm (with PP) and 340mm brakes, simply because the calipers are the same, the only difference is a bracket witch holds the caliper to
knuckle. Part # 0054203920
Rear rotors: are the same for PP and none-PP brakes, part # 1714230212 , Brembo part # 09.9257.41
Rear pads: A bit trickier, I have 3 part # 0054204120, 0034206220, 0044204920. From what I know they are all compatible, the only difference is that on some of them there are aluminium tabs (for easier removal, probably). I don't remember which part # I used for my car (I had slk55 calipers as well), but my pads had those tabs. (see picture)
You can find more pictures here: https://mbworld.org/forums/clk-class...omparison.html
Old Nov 9, 2022 | 01:18 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
I'm 90% sure they won't fit.
I remember reading that with stock wheels 18in was a requirement. Some custom wheels might fit.
But there is still 10% ....
Old Nov 9, 2022 | 02:04 PM
MitaWdb's Avatar
Coupe
Thanks for your prompt answer.
I’m looking for upgraded my w202 brakes.
Now I’m using 316 mm rotors with 4 pot calipers ( C43 AMG) with 17”wheels.
May be some ideas?
Old Nov 9, 2022 | 02:38 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
Speaking for a CLK perspective, as this is the W209 forum, the 360mm definitely do not fit. I expect the 340mm to not fit either. In fact, the front calipers are very close to the wheel if you have 19's. 17's wouldn't work at all.
