Engine Mount Part Number
I checked autohausaz and the part number is 11-13. Are the 2 part numbers the same? Why 2 part numbers?
I will go to an indie to install these mounts. When I went to replace my tie rods a few weeks ago, I did not buy the bolts and I have to rush to a local dealership to get them. Now I am wondering if I need any other parts in changing there mounts (motor and transmission mounts).
To replace these mounts, should I get any other parts; bolts, lugs,etc?
I passed my the indie (Sprinter specialist) and he should be replacing my mounts next week. While he changed the mounts for other cars including the C class, he was not sure if he had to disconnect the exhaust system to replace the mounts for my car. He also said that the AC might block the mounts. Now I am a bit concerned!
Since the engine will be raised, is there anything in that vicinity that I should replace or look at?
For my car, is the AC in the way?
He showed me that for the right mount, he would have to remove the alternator. For the left side, he would have to remove the exhaust (manifold?) and maybe other components on top. He said it's much easier for an E class.
Not sure if I should try another indy or maybe the dealership.
I called the dealership and they would charge 4.5 hrs to replace these mounts ts.
