Need Opinion? To Change or not change transmission fluid?
Thoughts from you guys?
Regular fluid changes will always be the best thing you can do.
What happened? Endless failures in the US. Then started this old wives tail that changing of fluid would somehow cause a failure & that old contaminated fluid somehow holds things together.
I've seen hundreds of samples of used fluid from these transmissions. It's tired at 60K Km's & needs to be changed. The filter also needs a change.
