top will not go down
Old Mar 24, 2014 | 10:18 PM
dannydodd's Avatar
clk320
I have been reading the forum but can't find the answer. The top started to open (don't know if she let the switch go too soon or what) then it just would not finish going up and would not close. I pushed down on the bottom of the window to get it to latch back (hope that didn't screw it up) and it did latch. The windows go up and down as they should and the roll bars will go up and down with the button. When you hold up the open button it flashes slow. Malfunction ( I know that!!!). What can or should I do now???
Old Mar 25, 2014 | 12:24 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's probably a bad microswitch that cause the top to stop operating. Forcing it could have broken something, but it's hard to know without looking at the system. I think the first step would be to pull the error codes from the soft top control unit. This might require a visit to the dealer, or at least a good indy with the proper diagnostic equipment.
Old Mar 27, 2014 | 12:38 AM
Paulers's Avatar
CLK550
Probably won't help
This probably won't help but when I had the wiring at the interior overhead light unplugged ( I had the whole assembly out) the top would not work. I don't know if the control module lives up there.
Old Mar 27, 2014 | 08:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't so, but I think there are microswitches in the windshield heard that may be wired into the OCP. Does it work with the OCP reinstalled?
Old Mar 27, 2014 | 10:33 PM
Paulers's Avatar
CLK550
Yes I just left it apart until I put the new mirror (With good microphone) in. Once all back together top worked. - also when windows do not work - top will not work. Not trying to hijack thread - just a couple of things that I found will prevent top from operating.
