HELP! W209 CLK trunk / boot won't open
Old Apr 12, 2014 | 01:18 PM
mlakhlani's Avatar
C219 2008 CLS 320CDI
Hi, Noob here...
I have a 2006 clk320 and for some reason i can't get into my trunk!
I've tried my button on the door to release, i've tried the remote and have tried the key hole on the trunk lid and have had no luck!
I have split rear seats and was wondering if there was a way I could unlatch then from inside the cabin to gain access to the trunk? - I know that I can release the seats from inside the trunk but as this is not an option, is there another way?
Thanks,
Lay
Old Apr 12, 2014 | 10:23 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just to make sure you are using the blade key properly - insert it into the lock, turn it 90-degrees counter-clockwise, then pull the handle.
Old Sep 1, 2016 | 10:41 AM
nicksc2's Avatar
2006 clk350 convertible
Hey Nick here,
I have a 06 clk350 convertible. Trunk won't open, top won't go down. Tried remote, key, and inside door release. I think its a fuse, but to get to the fuse box I have to open the trunk. Any suggestions. Thanx in advanced
Old Sep 1, 2016 | 12:13 PM
sailorben's Avatar
CLK W209
I don't know if the cabriolet is anything like the coupe in this regard, but check my post here, see if it helps,
https://mbworld.org/forums/clk-class...ey-inside.html
