CLK 320 Convertible Top signals "lock top"
CaptCrunch123, where are you located, and has any work been done to your top lately?
Does the warning go away by itself, or if you push the button to close the top? In the latter case, there may be a simple way to narrow this down.
Klaus
www.tophydraulicsinc.com
Rodney's suggestion is a good place for me to start, I noticed that since this problem began that when the top is fully closed, after operation is completed, that it does not "beep" as it once did.
Further thoughts???
it's time to start examining micro switches. Stop the opening or closing cycle where you have full access to the storage compartment, and take a visual of the micro switches in the brackets that the tonneau cover and the rear glass land on. See if one of those switches looks pushed out of its normal place.
Klaus
