Key issue Battery Drain - car goes dead CLK
Old Nov 13, 2014 | 04:55 PM
balacv's Avatar
CLK 320
Hi All - have been having this issue for a while now in my 05 CLK
The battery seems absolutely perfect. But at times when the car is off and I try to turn on the car, i put the key inside and the whole system goes dead. There is zero power in the car. I wont be able to turn the key too. I will have to jump start the car and the whole system is reset.
Got it checked and was informed it was a faulty EIS which was causing the battery to "drain". I even got that changed. It was fine for a while but the problem came back again. I put my key in, till then there was power and when I tried turning it to start the car the car just went dead with no power. Can some one please explain me whats happening?
Old Nov 13, 2014 | 07:43 PM
Glyn M Ruck's Avatar
Super Moderator
The most common cause of this problem is parasitic draw. The seat modules and/or the HVAC sniffer fan in the onerhead console not going to sleep.
Old Nov 14, 2014 | 09:30 AM
balacv's Avatar
CLK 320
Thanks Glyn for your reply. I had it checked for a parasitic draw as well. They were not able to find any drain except for the drain from the EIS module which i replaced later. Could it be the anti-theft module ? my car once stalled while driving and the system went dead. this happened a year ago. after that it hasnt stalled so far thankfully !
Old Dec 31, 2014 | 12:13 PM
Carolinarider's Avatar
2005 CLK500
I am having the exact same issue on the same model car. I had the dealer check it for a parasitic drain 12 months ago and nothing. Now I have another dead battery.
Old Jan 1, 2015 | 09:02 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The easiest way to find this is to put an ammeter on and then start pulling fuses to see which circuit is the culprit.
