2006 CLK500 factory Tail lights for sale
Old May 28, 2015 | 05:11 PM
gunzofnavarrone's Avatar
2007 CLK63, YUKON XL 2500 Duramax, Silverado 2500HD Duramax, CRF 450x
VERY good condition as the car only has 7500 miles on it and has been garaged. I have proper packaging to ship safely using the box that supplied the replacements I chose only for different styling. I am thinking $250 + shipping for both seems fair - open to offers. Thanks!
Old May 29, 2015 | 03:31 AM
Raden's Avatar
W209
Sir, do you ship to asia? Do the tail lights come with the bulb holder socket?
Old May 29, 2015 | 09:49 AM
I've never shipped out of the US prior but I'm sure it can be done. If you send me an address I can check with UPS on rate and time frame for delivery. I'll also follow
They do come with bulb holder socket and bulbs (see picture). I realize they do not come with the nuts to attach as you would use the nuts from your car as I did when I swapped.
Old May 31, 2015 | 11:07 PM
kb24forlife24's Avatar
None for now
Would you happen to know if it fits the pre-facelift cars? I have a 2005 and the tail light revision happened in 2006.
None for now
And just to clarify, these are OEM lights, right?
Old Jun 1, 2015 | 04:08 PM
Yes Original parts.
I don't know if it would fit a 2005...what would I look for? I owned an 05 prior as well and the rear tail lights look to be the same shape.
Old Jun 1, 2015 | 11:50 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
These will fit a pre-MY2006, but you will have to trim or bend a small bit of the metal fender panel to make them fit. It won't be visible; this piece is behind the tail light assembly.
Old Jun 1, 2015 | 11:51 PM
None for now
Will that ruin anything Rudeney?
Old Jun 1, 2015 | 11:52 PM
None for now
And is it worth it to bend the metal fender? I like the facelift tail lights, just not the aftermarket LED ones. So if the OEM ones would fit, they look like a great deal.
Old Jun 2, 2015 | 12:00 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No permanent damage. Like I said, it's just a small part of the fender sheet metal that is behind the tail light. The MY2006+ tail lights have a lighter deeper housing that needs the sheet metal removed/bent to fit.
Old Jun 2, 2015 | 12:01 AM
None for now
Sorry for me being lazy and not searching, but is there a thread on how to do it?
